Go to Post Yeah those design flaws kill you in the end. You especially hate finding out about them in competition. - Koko Ed [more]
Unread 27-01-2012, 09:46
drewkongs drewkongs is offline
FRC #0031 (Prime Movers)
drewkongs is an unknown quantity at this point
Axis 206 camera barrel jack
Howdy - we have lost the power cable to our Axis camera (the 206 model). Can someone that has their cable measure the diameter of the barrel jack with a pair of calipers?
I can't seem to find a connector that will work on anything I can salvage, so I've resorted to ordering one, but I still don't know the diameter.
It also didn't make sense to buy the axis branded adapter when I'm just going to cut the power brick off and put the connector on our robot...
Thanks!
Unread 27-01-2012, 09:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Axis 206 camera barrel jack
There's one at Radio Shack that kind of fits...I don't remember what the size is, but we have used it with the 206 and also with the new camera (1011?). If you can measure round stuff that small and get the numbers in mm, you should be able to figure it out.
Our 206 eventually died, the power connector on the camera came unsoldered from the circuit board. We decided it was worth $200 to buy a new camera that works reliably.
Unread 27-01-2012, 12:32
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
It seems to be a Radio Shack size H...at least that works for us.
http://www.radioshack.com/product/in...ductId=2102487
Unread 27-01-2012, 15:50
I can confirm that. We bought exactly that part last year and now have two camera power cables. The camera itself is easy enough to swap between practice and competition robots, but the no-connector 5 volt output on the Power Distribution takes entirely too much time and effort to deal with. Having a camera power plug on each 'bot is a real convenience.
Unread 27-01-2012, 22:28
As an electrical engineer, I pretty much pretend radio shack doesn't exist. They're overpriced, stock low-quality items, and what each store carries varies wildly. I typically just order from Digikey or Mouser (electronics component distributors).
A friend brought me a connector that fits, and its outer diameter measures 3.4mm and inner diameter measure 1.35mm.
I found a connector on Digikey (part number CP3-1003-ND), a 3.5mm outer diameter (I measured with calipers, there is lots more than 0.1mm worth of play on my camera) and it should work if anyone wants to order it from them instead of radioshack. It is half the price and I order from Digikey frequently anyway. You could also throw it on your Digikey voucher order if you were already ordering something else (we ordered a practice battery with our voucher - digikey p/n 522-1014-ND).
Unread 14-02-2012, 09:40
Bryscus's Avatar
Happy Birthday! Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
If you guys are going to go the Digikey route, you might want to try CP-2193-ND over the previous mentioned connector. It is essentially what one would cut from the Axis power supply - connector and pigtail (3.5mm OD x 1.35mm ID). Or CP-2197-ND is the bent version if you're into that kind of thing.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
