Go to Post The world is run by those who show up. - apalrd [more]
Unread 27-01-2012, 21:27
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
Analog Breakout?
We want to use a honeywell microswitch as a ball counter to determine the amount of balls the robot is currently holding. How do we connect this up and program for it? I think we connect this to the analog breakout but I'm not sure. Thanks in advance.
http://www.usfirst.org/uploadedFiles...icroswitch.pdf
Unread 27-01-2012, 23:07
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Re: Analog Breakout?
What language are you using to program your robot? Also, you can just put that on a i/o slot on your digital sidecar, analogue breakout is more for values between 0 and 1, not high-low values.
"No, you can't use the Kinect to do pelvic thrusts."
Unread 27-01-2012, 23:10
FRC #2869
We are going to program in java. And how would we connect the cables to the microswitch?
Unread 27-01-2012, 23:16
jp1247's Avatar
FRC #1247 (ROK BOT)
Then it should look something like this, probably not exactly though...
 DigitalInput ballCounter = new DigitalInput(I/O slot);
As for wiring it, you're going to want to take a PWM cable, clip off the male end, and solder the red and black wires to either terminal on the switch. Then plug the PWM into the digital i/o slot on your digital sidecar in the appropriate slot, and orientation.
Unread 27-01-2012, 23:23
FRC #2869
Okay, thanks
Unread 27-01-2012, 23:24
jp1247's Avatar
FRC #1247 (ROK BOT)
No problem.
Unread 28-01-2012, 00:23
Don't do this.
Red is +5 volts. Black is the power return. If the switch makes contact, it'll short out the 5 volt supply on your Digital Sidecar. The supply is protected against this, so it won't be ruined, but everything else connected to +5 will lose power for the duration of the switch activation.
What you should use are the black (-) and white or yellow (signal) wires. Black goes to the Common terminal on the microswitch. The signal wire connects to either the Normally Open or the Normally Closed terminal.
Unread 28-01-2012, 00:31
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Originally Posted by Alan Anderson View Post
Don't do this.
Agreed x100.
I will add that it is IMHO good practice to use a pick to undo the red wire's clip at the female end and remove the cable and metal terminal from the plug... you could call it extra insurance against shorting.
Unread 17-02-2012, 22:06
jp1247's Avatar
FRC #1247 (ROK BOT)
I apologize for the misinformation, that was how i was told to do it by last year's seniors, glad i have never put it into practice myself. Thanks for the info.
Unread 17-02-2012, 23:48
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
My personal preference is to fold back the power wire and heat shrink it so that the wire can't ever complete a circuit unless it's immersed in saline.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
