Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 26-01-2012, 16:17
yelk11 yelk11 is offline
FRC #3414
yelk11 is an unknown quantity at this point
controler
how do you connect the controller to the computer and use it in lab view. we are useing the joystick and plugged it into the computer and it won,t work
Unread 27-01-2012, 20:54
kdehaan42 kdehaan42 is offline
FRC #2874 (Eagles)
kdehaan42 is an unknown quantity at this point
Divers
Did you check the divers for the joystick? To do this go to My computer, right click, click Properties, then device manger in the top left corner, then look for the joystick
Unread 27-01-2012, 23:44
Re: controler
Are you writing a LabVIEW program to be run on the computer, or do you want to read the value of the joystick in a program running on the cRIO in the robot?
