Go to Post According to a recent study, 63% of teams admit they are behind. The other 37% are lying. - nitneylion452 [more]
Unread 27-01-2012, 23:56
Coin3's Avatar
Coin3 Coin3 is offline
AKA: Griffin Cerva
FRC #4110 (Deep Space Niners)
Coin3 is an unknown quantity at this point
FRC 4110 First Drive!
Be warned, half of the full 11 minute video is random shenanigans not directly pertaining to the robot.
http://youtu.be/JkhMVP12XBQ
We are hoping to be able to climb over the bar dividing the court instead of using the ramps. It sure is a pounding situation...
Unread 27-01-2012, 23:59
Andrew Lawrence
Posts: n/a
Re: FRC 4110 First Drive!
I really mean this:
You're a wide configuration. DO NOT go over the bump without lots of extra time/engineering. It's gonna be hard to do right, and with any error you're gonna fall.
Unread 28-01-2012, 00:02
Coin3's Avatar
AKA: Griffin Cerva
I'll be sure to tell our mentor.
We are a rookie team, and being 3 weeks in and just starting to drive, I think you are right about needing extra time.
Unread 28-01-2012, 00:04
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
You should also be testing on carpet. The extra traction will help(wheel wont slip), and youll get a better feel for how the game will be played
Unread 28-01-2012, 00:06
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Originally Posted by SuperNerd256 View Post
I really mean this:
Going over the bump wide is very possible, without that much extra work. It is slightly more complicated than if you are long, but with a low center of gravity it shouldn't be a problem.
Don't give up on a part of the game that may turn out to be critical (if you ever need to play defense you need to cross the bump, and if you are a good shooter many balls are likely to end up on the other side of the field) without first seeing what you can do.
Test going over the bump (correct length if possible), if you have trouble you might not want to do it or you might want to devote more time to getting a low center of gravity, but don't abandon it without testing.
Edit: you definitely want to try it with something closer to a real bump. The difference in material, as well as the difference in length will be important (especially since you seem to get stuck halfway across)
Unread 28-01-2012, 00:16
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
First, let me say congratulations on having a pretty well formed robot your rookie season. You're certainly headed in the right direction. Also, good look on the rest of your season If it helps, we're a 5 year veteran team and still trying to figure out how to get over the barrier without turning our 'bot into a hovercraft (if only for a few seconds).
On a small serious note, if you're testing the robot and people are getting near it, we on Chief Delphi would feel better if you wore safety glasses over your eyes. They work much better that way
To end on a happy note, SANDSTORM!
Academic Student (Forever)
Unread 28-01-2012, 00:25
deshnik deshnik is offline
AKA: Nikhil
FRC #0781 (Kinetic Knights)
Team Role: Student
deshnik is on a distinguished road
you also might want to use 4 cims and larger wheels it looked like you were using 6 or 8 in wheels or a mechanism
Unread 28-01-2012, 00:48
Coin3's Avatar
AKA: Griffin Cerva
Thanks for the comments and criticism guys.
The current wheels are 8 in., and are powered by one cim motor on each side connected with chain.
Unread 28-01-2012, 03:17
If you have no plans to use any more CIMs I suggest you do add 2 more. ESPECIALLY with those wheels, youll need all the help you can get.
Unread 28-01-2012, 03:40
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
I read this article on Popular Science. Maybe it will give you guys some inspiration???
http://www.popsci.com/technology/art...g-robot-design
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 28-01-2012, 10:44
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
I would like to suggest caution with the bump as well, since with a center of gravity as high as yours is, you could very easily tip over your robot if you hit the bump at an angle or were hit by a robot while crossing. also, while I'm not trying to discourage you, the actual bump has a lot less traction than the foam mats since it's made of steel. you should go get some thin sheet steel and put it over a wooden bump for tests
