Go to Post Come on guys, its not like it's rocket surgery or anything. - hallk [more]
Unread 28-01-2012, 00:31
eulerddx4
Posts: n/a
What type of motors for shooter
Hello,
Could anyone give me a suggestion as to what motors and gearing would work best for the shooter. I wanted to see what other teams are doing. Right now I am thinking the fisher price motors but I'm really not sure. The design of our shooter pretty simple. It's two wheels each sitting vertically on shafts. The wheels are about 8 inches in diameter.
Thanks
Unread 28-01-2012, 00:45
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: What type of motors for shooter
The topic of which motors to use for a shooter has been beaten to death in several threads, most often discussing CIMs vs Fisher-Price motors. A dozen teams have posted videos of shooters, and there are tons of pictures from 2006 which also involved shooting foam balls. Take a look at those and you'll at least get a good reference point. The things I've seen most commonly are Fisher-Price motors with gearing around 1:5 and CIMs around 1:1.
The best thing you can do is to build something quickly and test it. There are tons of variables involved: the mass of your wheels, the squeeze you put on the balls, the contact time, the shape and material of your wheels, etc. You really won't know how it will perform until you build it and shoot some balls, and you can't easily use physics to figure out what ratio you need.
Also, I would caution you against deciding on a wheel size and designing the rest of the shooter around them. It's quite possible that you'll get a particular gear ratio and have to work the wheel size around that. You won't necessarily be able to get the ideal ratio, but you may be able to vary the size of your wheel.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
