Go to Post FIRST: The hardest thing you'll ever love to do. - Stephen Kowski [more]
Unread 26-01-2012, 18:46
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Troubleshooting a jag
Can you safely connect a jag to direct power in order to see if it still works? It does not have the odor of a burned out electronic and no physical signs of damage. It is one of our new jags so i refuse to beleive it is burned out until i can prove it. Can anyone help me? Thankyou.
Love, Peace, and Robot Grease
Unread 26-01-2012, 20:15
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Troubleshooting a jag
Before you go too far, can you describe the symptoms you are observing that make you think it is bad? For example, does the indicator light come on at all?
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 26-01-2012, 21:42
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Am posting response for them as they are working on other things currently:
Light was flashing
Manipulated joystick
No response from gearbox (which may or may not have been due to a coding problem)
Loud whirring from jag began (definately not due to coding problem)
Rebooted system:
No indicator light
Opened jag case:
No burnt odor coming from circuit board
No obvious signs of bad or melted solder joints
Fan spins freely
Wires did not appear to be touching blades
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 26-01-2012, 23:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
First things first, you can directly connect the jag to 12V with no breakers for testing purposes. If you have a CAN serial cable, you can use that plus BDC-COMM to do diagnostics on the Jag. Otherwise you'll only see a flashing yellow light without a good signal PWM signal.
Secondly, what color was it flashing when it wasn't working? Slow yellow means you don't have a good PWM signal or CAN network. Fast Red or Green means you're sending it a reverse/forward command. Slow red means there's a voltage, temperature, or limit switch fault.
Thirdly, the whirring you hear is quite likely normal. That's the cooling fan. On a 2012 Jaguar, the fan runs for 1 second after power on, and runs whenever you're sending a forward/reverse command.
Unread 27-01-2012, 12:10
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Solid Red/Green means full reverse/forward.
Unread 27-01-2012, 12:35
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Just to clarify, both these statements are true.
Unread 28-01-2012, 00:34
rsegrest's Avatar
Sorry guys, jumped to work today and this is the first chance we've had to get back to this. Will run the testing tomorrow and get back with you. Thank you for the advice!
~ Unknown
Unread 28-01-2012, 14:04
rsegrest's Avatar
Ok, so newbie question...we are using C++, how do we use BDC-COMM for testing purposes OR where can we find the info on how to do this?
BTW This is an inexperienced electrical team as far as diagnosing and troubleshooting anything more technical than faulty wiring and calibration issues...
Nevermind. Just found the info I was looking for regarding BDC-COMM...
~ Unknown
Last edited by rsegrest : 28-01-2012 at 14:07. Reason: Hi-5 to face for not finding the info on ti.com first...
