Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 27-01-2012, 22:04
Stagger007 Stagger007 is offline
FRC #4379
Stagger007 is an unknown quantity at this point
Exclamation Help On 360 servo
Hello I'm part of a rookie team and were getting used to all the programming and i decided to use a 360 servo that is controlled by the joystick's x-axis but when i put it on tele-up all it does is spin in circles. Im guessing it has something to do with the bounds so I'm guessing i have use the setBOunds() method but i have no idea on what to make the parameters like the deadmax, max, center act. Thank you.
Unread 28-01-2012, 03:47
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Help On 360 servo
Can you say more about the 360 servo? Are you referring to the Vex motor supplied in the kit of parts?
Brad
Brad Miller
Robotics Resource Center
Unread 28-01-2012, 09:24
FRC #4379
It is a tetrix 360 servo
Unread 28-01-2012, 13:49
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
we use the servo class
do you mean these?
http://www.andymark.com/product-p/am-0010.htm
if so, we use the servo class
http://www.wbrobotics.com/javadoc/ed...ibj/Servo.html
and you just use the pwm cable for it.
