Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 28-01-2012, 12:05
GLaDOS GLaDOS is offline
FRC #3215
GLaDOS is an unknown quantity at this point
Question About the Distance in the Vision Processing example
Hello all,
I've read the NI white paper on Vision tracking, and I've been running the example included with LabVIEW. However, when we run our camera to track example targets on the wall, the distances are different.
My understanding is that the distance outputted is the distance from the camera lens to the wall...but the distances for the different targets vary, which makes me wonder if the distance d is actually the distance from the camera to the center of a rectangle.
Can anyone confirm what the distance outputted by this example is measuring?
Thanks!
Unread 28-01-2012, 13:02
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: Question About the Distance in the Vision Processing example
I've never done it but the way I assume it works is the program takes the size of the object and checks how far away you are by seeing how much smaller it is than the original size of the object.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 28-01-2012, 18:00
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
In my experimentation with the out of the box vision software provided by National Instruments, the distance I measured correlated very well with the distance from the camera lens to the center of the rectangle.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 29-01-2012, 14:12
If you select the wrong camera, your distances will be off.
