Go to Post When I encounter Dave at competitions and meetings, I find him to be kind, helpful, almost too nice. When I read his hints, I find him to be EVIL! - Ken Loyd [more]
Unread 28-01-2012, 13:47
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: 8 Inch rule?????
The rules state that the bumper must cover the "exterior vertices of the Frame Perimeter". I'm 93% sure it means 8'' of the chassis itself.
Unread 28-01-2012, 13:56
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Q. Does the 8" of bumpers required on each side of vertex include the 3" of the bumper meeting it from the connected side? Or does the bumper need to be 8" of plywood with noodle. In Figure 4-1 it appears that the upper left horizontal bumper is 8", and the vertical is 6" with no plywood on the end.
FRC3931 2012-01-24
A. Per Rule [R27], the Bumper must be at least 8 in. Per Rule [R28], the Bumper must be backed by plywood. Thus, the plywood must be 8 in. The figures in Section 4.1.6 are for illustrative purposes only and are not drawn to scale.
(emphasis mine)
I think this clarifies it pretty well. Good Luck
Unread 28-01-2012, 21:25
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
garyv is right.
go check the official Q&A the posted answered this question several times.
(not exact wording but yeah):
A: The 8in. of frame perimeter directly next to the vertex must be covered by bumpers...
cole?
Unread 28-01-2012, 22:22
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
So the frame has to be 8 inches? I'm sorry, it's just that we can't find the exact answer anywhere.
If the plywood has to be 8 inches, I'm pretty sure there's a rule that all of the plywood has to be supported by the frame. But I just want to double check it.
This is our case: Frame is 27 x 37, the 27 inches side has 6 inches of frame on each side and 15 inches of opening in the middle for the ball. Would we have to change both of those 6 inches to 8 inches? If so, that would kinda suck - we'd only have about 11 inches of opening.
Unread 28-01-2012, 22:25
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Can u split the 8"'s up on one side? Like 5 inches on the Front on both the left and right sides?
https://plus.google.com/photos/10207...CMXV6O3rlcPYPA
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 28-01-2012, 22:42
8" from the vertex of the frame perimeter on each side of the vertex of the frame perimeter. Not 8" on the side of the robot. Not 5" on the perimeter + 3" outside the perimeter. 8" from the vertex of the frame perimeter on each side of the vertex of the frame perimeter. The configuration you are proposing should not pass inspection at any event, as it only has 5" on one side of two vertices.
Neal, I would suggest understanding the implications of [R33] as currently written, which says quite clearly that 1) bumpers must be supported by the frame of the robot, 2) as part of that support there is a maximum gap depth or width, and 3) as part of the support the ends of the bumper need to be supported (this particular item was added in Update 2, IIRC). Because of that, you will need at least the equivalent of 8" of frame supporting the bumpers. Yeah, you'd only have 11" of opening on the narrow side. So does everyone else who is smart enough to build their robots 1" undersize to avoid trouble with the size box. At least you're not getting told this at your first regional...
Unread 29-01-2012, 13:42
neal's Avatar
Neal
Thanks for clarification, Eric. We did make them 8 inches. Now we just hope our grabber works well with 11" opening.
That would be really bad if we never changed it and they told us at the regionals.
Unread 28-01-2012, 22:45
swootton swootton is offline
AKA: Steve Wootton
FRC #4055 (NRG4055)
swootton is on a distinguished road
We asked a question on the first Q&A and got a very specific answer. YES the bumper has to be 8" and YES the opening will be 11" or so if you load from the front/rear.
Unread 28-01-2012, 23:12
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
This is how I see it.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 28-01-2012, 23:34
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
That is correct. 8 inches on each side.
Unread 28-01-2012, 23:38
Is it just me or should the GDC re-write the bumper rules so that they arent so confusing!
2013-Present
2010-2013
Unread 28-01-2012, 23:40
Andrew Lawrence
Posts: n/a
Does it mean 8 inches for each side of the robot combined, or 8 inches on the robot in a row?
In other words, can we have two sets of 4" bumpers on each vertice (know I spelled it wrong) of our ball intake side making 8 inches total for side, or must we have 8 inches on each of the vertices?
Thanks!
Unread 28-01-2012, 23:55
AKA: Pat Miller
If you drive long ways, and you have an opening for a pick up, then you have 8 inch of frame on each side of the pick. Giving you about an 11 inch opening for said pick up.
Unread 28-01-2012, 23:57
Thanks!
The intent of the rule and the Q&A answers that I've seen has been pretty clear that the 8" is measured from the vertex. That's not 8" per side. That's 8" from the vertex, per side, per vertex.
And on the GDC rewriting the bumper rules so they aren't as confusing, they did, or at least made a stab at it. The problem is that they are having non-100% coverage for the first time since 2009. And instead of having a percentage as they did in 2008(?) and 2009, they specified a length from a corner vertex. The problem is that people are having trouble understanding what "at least 8 in. of Bumper must be placed on each side of each exterior vertex" means (or they may just plain want it to not mean what they understand it means).
Then again... The definition of Bumper may not be clear in that rule. Which is why the very next rule defines how to construct a Bumper, and what a Bumper is.
Unread 29-01-2012, 11:23
4.1.6 Bumper Rules
Robots are required to use Bumpers to protect all exterior vertices of the Frame Perimeter. For adequate
protection, at least 8 in. of Bumper must be placed on each side of each exterior vertex
