Go to Post Just wear your safety glasses. They can be stylish, too! - Eugenia Gabrielov [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-01-2012, 03:15
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
CAN troubles with Black Jaguars
Our team had always used the Jaguar controllers in PWM mode, but this year we wanted to jump overto CANbus control. We thought we had done enough prep work, downloading firmware and getting BDC-COMM onto an old laptop with a serial port.
Our black jaguars flashed to the new firmware just fine, and all were given unique ID's. When we tried to update our beige jaguars, we hit a major snag. None of them were visible when hooked up to a single bridging black jaguar. We hooked up two black jaguars, and could not see any beyond the first, directly connected to the serial port.
We did web searches and scoured this forum. The most thrown-out solution to the same problem, as encountered by others were faulty terminators and faulty cables. After much wasted time trying to find non-existant faults in these components, we finally found the source of our problems.
In our case, all six of our black jaguars had faulty RJ-11 jacks (CAN - only), and two also had faulty RJ-12 jacks (Serial + CAN). Oddly, not a single one of our seven beige jaguars had a single faulty port. The problem is a minor manufacturing defect, where the sprung contactor wires in the jack are just not sprung enough. This causes contact to be lost with the slightest jostle of the cable.
We discovered this by noting that some connections could enable CAN communication, but lost communication If the cable was slightly disturbed. We had a lot of movement in the jacks. When we looked into the port, we found one of the center pair of contacts almost flat against the outer wall of the jack housing.
I carefully stretched these wires out with some needle pointed tweezers, and tested every port until I could maintain CAN communications, no matter how much I wiggled the cables. Now, all of our jaguars are maintaining communication over CAN
Unread 17-01-2012, 09:57
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: CAN troubles with Black Jaguars
I think we may have experienced this problem as well. I bought off the shelf cables because I suspected my home made cables. We still had the problem with the new cables until I reached down and wiggled one and all of a sudden all were online! The problem was intermittent after that (some days I had all online, some days only the first in the chain). One of the benefits of CAN (opposed to PWM) is supposed to be the locking connectors. What can we do to get the manufacturer to take a serious look at this?
Unread 17-01-2012, 11:47
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Thanks to both of you for pointing out this issue. We'll investigate to see what happened and if this is a wide spread issue or isolated to a batch of bad sockets.
-David
Unread 17-01-2012, 11:56
AKA: David Yanoshak
If either of you happen to still have a Jaguar with the bent pins, could you please post a picture of them? This will help us determine the root cause.
Unread 18-01-2012, 03:24
Levansic's Avatar
AKA: Len Evansic
Sorry. I fixed all of our working black jaguars before thinking about taking any pictures. We had one that was fried last year that I didn't fix, but I think it was pitched over the weekend.
We only had two new 2012 KOP jaguars. Both had bad RJ-11 ports, and one had a bad RJ-12 port. I mean that port worked for the serial connection, but was faulty for CAN. These two units were untouched by student hands before this Saturday, so nothing got improperly jammed into the ports.
We were not aware of the connectivity issues of our jaguars before now, because we hadn't attempted using CAN. Our issues were specific to the black jaguars, from all years, and not the older beige ones.
Unread 23-01-2012, 02:37
Levansic's Avatar
AKA: Len Evansic
OK, I got a picture of our remaining black jaguar, which I did not repair. This unfortunate unit was damaged in a finals match, in an earlier year. The RJ-11 port on this unit was not as bad as the other black jaguars that I had to repair.
If you look carefully at the two ports, you can see that the wires in the RJ-12 (6p6c) port on the left are pretty uniform, and are sprung down about half-way through their wire guides on the bottom. This is a "good" port.
Now, compare that to the wires in the RJ-11 (6p4c) port on the right. Those wires are not uniform, and the last three, especially the fourth one, are close to the back wall of the port. The first wire is sprung almost the same amount as the wires on the RJ-12 port.
On most of our black jaguars, the distance of these wires from the back wall alternated. For example wire 2 and 4 would be almost flat, while 1 and 3 would be sprung out more. I used a pair of needle tweezers to pull these wires out. They often would jump tracks to a neighboring wire guide. I would then move them back to the correct track, and test the port by inserting a plug.
This weekend, we reassembled the base of our robot from last year, but wired it with CAN. After tweaking the ports on our black jags, I was unable to get any comm errors, no matter how much we wiggled each and every cable.
We are so ready to swear off PWM cables forever!
-- Len
Unread 24-01-2012, 12:22
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
I never even thought of looking at the connector. *smacks forehead* We used CAN bus last year, and had many issues with CAN bus timeouts. It was very intermittent, and as you say everyone suggests that it's either termination or cables. I've replace these over and over with no noticeable improvement. I'll take a look at the connectors tonight. We are using the 2CAN, and for a while I believed that it was some sort of electrical issue with brown out, and dropped messages. A faulty connector could be the root cause that I've been looking for. I'll let you know what I find.
---Michael J Coss FIRST Team 303 - Mentor
Unread 24-01-2012, 14:05
I checked two jags we recieved this year and two from last year. One from last year had what we deemed a bad 'net' port as described in the original post. The others looked fine. I tried taking pictures but they didn't turn out all that great.
Unread 24-01-2012, 19:59
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
This was something we looked at when we first encountered issues. We had made cables ourselves and there was ample room for this to happen.
I can confirm that none of the black Jaguars we removed exhibit this behavior.
Also, I did literally remove one of these connectors and put a cable on there at one point (just in case...so much for the warranty).
I believe I currently have access to 9 of these black Jaguars and a few of the older model.
If there's interest I'm willing to photograph these connectors on our units.
Mind you we could make our units talk on CAN, we could even pull on and otherwise malign the cables in the ports, but when the robot was on the floor driving around we'd start to accumulate errors.
We did develop a bad cable in our backup robot at one point (March 2011 I think), and when we did we had to replace it. The system would not cooperate with that. We did get some intermittent functionality but nothing even close to expectations.
Unread 26-01-2012, 13:58
FRC #0303
Checked last night and no such luck. All look Jaguar connectors look fine to me. We also tested that the end to end termination was reading the correct resistance. So back to the same issue we had last year with CAN: Intermittent timeout of messages, with no clear cut root cause or solution.
One experiment that I will be running tonight is the use of sync groups. My code makes extensive use of sync groups for updating any motors that are linked together, I doubt that it's involved with my problem but I'll grasp at any straw at this point.
Unfortunately, looking at the forums CAN issues seem to be just as rampant this year You'd think we'd learn our lesson.
Unread 26-01-2012, 14:44
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Sorry to hear you're still having trouble. Do you have LabVIEW installed? Have you read Tutorial 9 on the getting started window in LabVIEW? It describes best practices and may give you some ideas to consider.
What language are you programming in? The C++ implementation saw some improvements this year, to come up to the level that LabVIEW was last year. LabVIEW then surpassed it again (wrt supporting the new Jag firmware features). C++ may support the new features a little later this season. The Jag firmware was released too late to get all the APIs updated to support them in time for kick-off release.
-Joe
Unread 26-01-2012, 16:36
techhelpbb's Avatar
Seeing as you're in Bridgewater, NJ (which I often drive thru)...and I'm in Mount Olive, NJ...if you'd like to work together on this at some point please feel free to contact me.
That being said, the timeout errors are a little different in nature between the 2CAN and RS232 bridge.
Can you share which you are using?
Unread 26-01-2012, 23:04
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
The problem is one of two places, the wiring or the code.
You can quickly rule out the wiring by connecting your first jag to a computer and communicating with the bus using BDC-COMM (this pulls your software out of the loop). If that works then it is your code.
I would suggest getting ONE jaguar working over CAN. Verify that works, then extend your known working code to include communicating with more Jaguars.
One problem we ran into early on was sending too many messages onto the CAN bus at once. We were driving three groups of jaguars (master/slave configuration) using synch groups. We were not limiting the frequency at which the messages were being communicated, and things didn't run reliably. I don't know what language you're using, but you'll want to add a time delay or wait between transmissions to ensure you don't flood the bus.
This is an issue we saw over the RS232/CAN bridge. I'd expect this problem would be less pronounced using the 2CAN.
http://team2168.org
Unread 27-01-2012, 09:47
techhelpbb's Avatar
I completely agree that between these 2 issues there are a massive number of possible sources of issues.
However, I should like to point out that in the past errors have been found in the Jaguars and I have a very intricate test environment for them and I've seen a few things that despite entirely faithful efforts might make it difficult to pin down the exact cause.
I have not seen his particular environment however.
Also, it's entirely possible that you can instigate issues if you overload the Jaguars (and the circuit protection behind them) without noticing it. The Victors in this regard seem a bit less sensitive from incidental examples I have seen. In a way the CAN bus can become a single point of failure that with PWM on the Victors wouldn't otherwise exist.
Unread 28-01-2012, 14:29
otherguy's Avatar
sparkE
AKA: James
So here's an interesting development.
We had one jag that came in the KOP that we couldn't communicate with over BDC-COMM. We had 5 others flashed and working, so we didn't look into the root cause until today.
When power is supplied the LED flashes amber, but no comms could be established... I looked at the connectors to see if we had the bent pin issue described above and to my surprise I find this!
Hopefully this is clear enough
ID:	11607Click image for larger version
RS232 rx/tx operates over pin 1 and 6 on the left port on the Jags. It's a little difficult to communicate if those pins aren't even present in the connector!
TI seriously needs to focus on their quality control. I wonder how many other teams are going to run into the same issue and don't know enough to think to look for 6 conductors on a connector. This isn't a fun one to troubleshoot if you're still questioning if your cables/serial adapter haven't been verified working yet.
http://team2168.org
