Go to Post You know you've been in FIRST way too long when you can remember all those hints... even down to exact wording... and only have to look up the most recent. - EricH [more]
Unread 28-01-2012, 16:51
Re: Router Connectivity Poor
Especially if using LV, be sure to click to the Diagnostics tab of the DS and see if there are errors. Errors drastically slow the cRIO and will cause lag. Finally, be sure to click to the Charts tab of the DS and see what the CPU, round trip time, and dropped packets are. Those measurements will help us to guess at what is causing the lag.
Greg McKaskle
Unread 28-01-2012, 17:23
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
The only error I can remember is the axis camera is not found because we do not have it set up yet.
Unread 28-01-2012, 20:47
dakaufma dakaufma is offline
AKA: David Kaufman
FRC #0449 (Blair Robot Project)
dakaufma is an unknown quantity at this point
Any unhandled error can slow down your code; if the camera isn't connected/configured (even temporarily) you should disable it in the Begin and Vision VIs. That being said, if your code is working properly with a wired connection then this isn't your main problem.
