Go to Post Not everything has to be cashed in or has to have instant recognition. Sometimes being a part of a program of value and opportunity is enough. And, what you put into the program is what you get out of it. - JaneYoung [more]
Unread 28-01-2012, 11:13
DollyV331 DollyV331 is offline
FRC #4409
DollyV331 is an unknown quantity at this point
cRIO wont connect to classmate?
Hey, I'm Dolly from team 4409.
I've been programming on LabVIEW and I went to connect the program to the cRIO and it won't connect. It gives me a conflict message saying "Connection failed. The network address might be invalid or the target is not responding."
Does anybody have any tips that may help us fix this problem? It was working just fine last week.
Unread 28-01-2012, 13:27
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: cRIO wont connect to classmate?
Are you using the yellow crossover cable? Are the green and yellow(orange) lights flashing or steady on the cRIO itself?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 28-01-2012, 17:02
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Exactly. My guess is that you are using the wrong cable.
No leaks. Ever.
Unread 28-01-2012, 17:09
thndrmnky thndrmnky is offline
3596
FRC #3596
thndrmnky is an unknown quantity at this point
make sure windows firewall is off, that solved our connection problems
Unread 29-01-2012, 01:14
How physically are you connecting your programming computer to the cRIO?
What is the IP address of your computer?
