Go to Post I'm not sure why, but I'm getting this picture in my head of a bunch of engineers, huddled in deer blinds with 22's, waiting for the right power wheels toy to drive by. - Tom Line [more]
Unread 28-01-2012, 17:05
Re: Air Compressor Will Not Initiate
Originally Posted by Slothbron View Post
We believe the wiring is all correct for it and the pressure switch.
You believe it's wired properly. Why should we believe it? The proper wiring is pretty simple. Tell us how you've done it so we can confirm it. It's often best to double-check the simple stuff before putting forth much effort trying to think of what else might be wrong.
Unread 29-01-2012, 01:08
Slothbron's Avatar
Slothbron Slothbron is offline
AKA: Nathan
FRC #3216 (Missoula Robotics Team)
Slothbron is an unknown quantity at this point
Ok so we have a pwm cable coming from the spike relay of the air compressor to relay spot 1 on the sidecar. Then the pressure switch is wired to the DIO spot 1 on the sidecar. Specifically the signal pin and + pin.
MRT 3216
2010- Salt lake City Highest Rookie Team seed
Unread 29-01-2012, 02:42
For a switch input to be read by the program, you need to use the signal pin and the ground (-) pin. The Digital Sidecar inputs are already at +5 volts when nothing is connected to them. You have to pull them low in order to register a change.
Unread 29-01-2012, 13:38
Slothbron's Avatar
AKA: Nathan
Ok so you fixed the pins now we have one wire going to the signal and one to the negative. But it will still not start when we enable the robot.
MRT 3216
Unread 29-01-2012, 18:02
I assume you followed Greg's advice to make the compressor control loop active in Periodic Tasks?
Disconnect the pressure switch from the Digital Sidecar and measure continuity between the contacts. They should be shorted together when the pressure is too low. If there is an open circuit, replace the switch. Check the Digital Sidecar and look to see whether the relay is being asked to turn on (there should be a green LED lit next to the pins for relay #1). If it is, look at the LED on the Spike (it should change from yellow to green when the robot is enabled).
