Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 28-01-2012, 11:24
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
Exclamation Cant download new projects to Crio
Hello, I am trying to do some version control in Windriver but I cant seem to make any of the new projects download. The origional project works but not the new ones. I have already tried switching the .out files but it still refuses to say I have Robot code despite the fact that it downloads fine.
Unread 28-01-2012, 13:24
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Cant download new projects to Crio
Are you undeploying the code as well? Usually I undeploy code before I deploy new code in windriver. Also try restarting the robot before connecting it to the driver station.
Let me know if that works/you already tried it.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 28-01-2012, 18:18
Method's Avatar
Method Method is offline
Method is an unknown quantity at this point
We have the same issue- on two computers: we updated and it no longer works. I tried to re image the CRIO but it says that the image isn't at the following file path:
C:\Program Files (x86)\National Instruments\LabVIEW 2011\project\CRIO Tool/FRC Tools
This seems a coincidence when accompanied with the fact that there are two posts here about it... We also tried to re install everything.
Unread 28-01-2012, 18:40
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Method, make sure you are installing everything in the correct order. I'll update this post with the c++ order when I get off of work tonight.
There are 3 mandatory updates for the NI FIRST Robotics Software 2012 and they should be installed in the following order:
LabVIEW Update
Utilities Update
Driver Station Update
updates can be found here
http://joule.ni.com/nidu/cds/view/p/id/2261/lang/en
Once you download and install these in the correct order you should have the file in FRC Tools. If not let me know.
Unread 29-01-2012, 00:35
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
**JAVA FTW**
Unread 29-01-2012, 13:05
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Make sure you have the START_ROBOT_CLASS macro in your program. You can get the "No robot code" error even if there's a (useless) .out file.
