Go to Post The future is a dark and mysterious place, and trying to force our current methods on that are patently absurd. - Taylor [more]
Unread 28-01-2012, 19:04
Re: CAN problems
Originally Posted by zekrysis View Post
ERROR <Code> -1073807246 occurred at NetComm_CAN_Send.vi:3
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
What you said you did to fix the problem doesn't match what I thought the error indicated. It's been pointed out in other threads that you need to disable the CONSOLE OUT switch on the cRIO if you want to use the Serial-to-CAN gateway plugin.
Unread 28-01-2012, 22:13
zekrysis zekrysis is offline
FRC #3616 (Phenomena)
zekrysis is an unknown quantity at this point
Re: CAN problems
yes I noticed that when I reimaged the CRIO I flipped the switch and retried and got a time out error so I then changed the time out on it only to find out that the jaguars' firmware was out of date. after much searching I finally found the firmware hidden away in a corner on the texas instruments website (honestly they should fire their webmaster, organization on that website is horrible) and after updating can was now working.
