Go to Post The term normal is relative to CADer side of me. When compared to the rest of society, there is no normal side of me. - Pault [more]
Unread 28-01-2012, 19:39
hugo3337's Avatar
hugo3337 hugo3337 is offline
FRC #3753 (BulahBots!)
hugo3337 is on a distinguished road
Motor for lowering the bridge/ramp?
any suggestions on what motor should be used to lower the bridge/ramp?
Unread 28-01-2012, 19:41
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Re: Motor for lowering the bridge/ramp?
A servo (just kidding) I would use a window motor.
Unread 28-01-2012, 20:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Any motor will do. The question is how long of a lever arm are you using (IE how much torque do you need) and how fast do you want it to go (how much you need to gear it down to attain that torque).
___________________
- Tennyson, Ulysses
Unread 28-01-2012, 20:29
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I second that, a window motor won't back-drive so you can lower the bridge and not worry about having to put power to your motor in order to keep the bridge down.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 28-01-2012, 20:33
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I'd be a little concerned with a window motor, as (depending on the mechanism being used) the bridge manipulator may need to change angle as you approach the bridge (once its tipped)
___________________
- Tennyson, Ulysses
Unread 28-01-2012, 20:40
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
How about pneumatics?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 28-01-2012, 20:46
pfreivald's Avatar
AKA: Patrick Freivald
The correct way to answer this question is by doing the math. Figure out how much torque you need to lower the bridge, and then plan accordingly.
If this confuses you, talk to your physics teacher or an engineering mentor on your team. The problem is high-school level physics to determine the torque to lower the bridge, the force necessary to create that torque with different lever arms from your robot, and also to determine the various times that (ideal) motors would take to perform the task while creating that force.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
