Re: Team 256's ball shooter prototype
Which motors/gearbox are you using?
I cannot believe I am saying this, but they are Banebots-775s. We got our order in today (had no idea they were ordered), and decided it may be possible to try them. They worked, so we plugged them into some CIM-U-LATOR gearboxes and they work like a charm!
We've never had a problem with 775's yet, so maybe they work for us! ![]() |
http://banebots.com/p/S24K-C1-7 our 1:16 planetary gearbox seems too slow |
I imagine 1:16 would be. I figure 1:4-ish would be more appropriate.
That looks like a ton of compression. Could you guys perhaps be designing a modular compression shooter to change how far you shot it. If so, that's really clever.
#7
Just kidding. No, we have a set compression, and will just vary our shooting speed if needed, and some extra stuff.Although to any team who wants to, this is an excellent idea! I suggest it to any team looking for suggestions on shooters. |
#8
Yeah man O.O
a few questions: are those the 2010 kop wheels? is it marking the balls up any? is are you compressing more that 2"? |
#9
2) No marks on the balls! ![]() 3) I think a bit more than 2 inches, maybe . I'll let you figure that out. |
#10
Check your repeatability. You want to make sure your shooter is extremely repeatable.
When shooting, sources of error will include distance, alignment, .... ensure your prototype is shooting in the same spot every shot. Find the variables that influence this. When comparing a 3 point shot versus a 2 point "dunk", your 3 pt. shot needs to be at least 66% as accurrate as what you believe a 2 pt. dunk to be. |
#11
If so, then there is likely an easier way to score that doesn't require a shooter protype that can shoot 25 feet.
#13
We don't loose any power with our current designs, and it gives us the advantage of versatility. |
