Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 28-01-2012, 23:12
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Re: Team 256's ball shooter prototype
Originally Posted by jblay View Post
That looks like a ton of compression.
Yeah man O.O
a few questions:
are those the 2010 kop wheels?
is it marking the balls up any?
is are you compressing more that 2"?
cole?
Unread 28-01-2012, 23:20
Andrew Lawrence
Posts: n/a
Originally Posted by 372 lives on View Post
Yeah man O.O
a few questions:
1) Those are the 2009 KOP wheels, however we plan on using different ones.
2) No marks on the balls!
3) I think a bit more than 2 inches, maybe . I'll let you figure that out.
Unread 29-01-2012, 08:53
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Check your repeatability. You want to make sure your shooter is extremely repeatable.
When shooting, sources of error will include distance, alignment, .... ensure your prototype is shooting in the same spot every shot. Find the variables that influence this.
When comparing a 3 point shot versus a 2 point "dunk", your 3 pt. shot needs to be at least 66% as accurrate as what you believe a 2 pt. dunk to be.
Unread 29-01-2012, 12:44
Andrew Lawrence
Posts: n/a
We're going for the 2 point dunk most of the time.
Unread 29-01-2012, 12:48
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
If so, then there is likely an easier way to score that doesn't require a shooter protype that can shoot 25 feet.
Unread 29-01-2012, 12:52
Andrew Lawrence
Posts: n/a
Yes, but we also want the ability to shoot far. It makes a team more versatile if they can drive around and score balls really quickly with a dunk, and if needed feed their alliance balls from their alley, making an occasional basket.
We don't loose any power with our current designs, and it gives us the advantage of versatility.
