Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 28-01-2012, 15:33
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
OPR Formula
This is going to sound extremely stupid, but what is the formula for OPR?
Thanks in advance.
Unread 28-01-2012, 16:18
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: OPR Formula
That is not a stupid question.
OPR is actually a system of simultaneous equations. The difficulty lies in solving that many simultaneous equations.
For instance. In a standard district event in Michigan, there might be 80 matches.
Each match has equations that lay out like this:
Robot_1_score+Robot_2_score+Robot_3_score=Red_Scor e
Robot_4_score+Robot_5_score+Robot_6_score=Blue_Sco re
So, in the end you'll have a system with 160 equations, and 40 variables (each robot is one variable, as shown in the equations above). The trick is solving those equations. Until just recently, excel didn't have the firepower to do it unless you used macros. However, with the newer versions, the Matrix formulas are powerful enough to do it. Keep in mind this isn't like algebra - the computer has to iterate to find an answer.
This is not a simple process. It is fairly complicated. Look up "solving simultaneous equations using matrices" in excel, and you should be able to find some examples. That is how we wrote our OPR. It requires pretty in-depth knowledge of excel though. You'll have to understand named arrays, matrix math functions, and array formulas.
2834 the Bionic Barons put out an awesome OPR sheet that handles the calculations through some open-source macro code. It is far more complex (to me) than using matrix formulae, because I have never used macros and vb programming in excel.
Of course, programs like matlab have more advanced equation solvers and you may be able to easily write a program to perform the calculations.
Unread 28-01-2012, 16:31
Re: OPR Formula
Tom,
I've done a fair amount of work with large overdetermined systems of equations (20,000 equations in 6,000 variables).
I'd like to play around with some of this data. Maybe I could write and post a small app. Do you know where I could get a couple of CSV, or whitespace-delimited, or fixed-field text files from 2011?
Thanks.
Unread 28-01-2012, 16:59
Tom Line's Avatar
Re: OPR Formula
I believe you can copy and paste from the old scores on the FIRST website. For instance, here:
http://www2.usfirst.org/2011comp/eve...chresults.html
That is how I developed ours. I've never tried to do the whole web-scrape or download the scores automatically as they are posted by FIRST. If, however, someone could explain how that's done it would be absolutely wonderful!
Unread 28-01-2012, 19:07
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: OPR Formula
In newer versions of Excel, go to the Data tab, and then click (under Get External Data - left most panel) "From Web". Then, you can put the URL of the results page into the little browser window that pops up and then select the table with match results. To refresh, click "Refresh All" in the Connections pane (still on the data tab).
Unread 28-01-2012, 19:13
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: OPR Formula
Also, the FIRST FMS system uploads its data in twitter posts under @frcfms so you could scrape a lot more data from that since it tells of penalties point total for instance.
Unread 28-01-2012, 19:25
Re: OPR Formula
Is there a CSV or whitespace-delimited or fixed-field text file somewhere that has all the scores from all the matches around the country (world) in one file for 2011?
Unread 28-01-2012, 20:38
plnyyanks's Avatar
AKA: Phil Lopreiato
Re: OPR Formula
How's this? I just threw it together by scraping all the competitions and putting them in one big file.
Also, some fun facts I found:
- there were 5,258 FRC matches played in 2011
- There were 357,981 points scored total
- The average individual alliance score was 34.04 points
- The average total number of points per match was 68.08311145 points
- The highest alliance score was 147 points
Unread 28-01-2012, 21:01
Free Agent
Re: OPR Formula
Many thanks for all the info. Can I assume the same basic principles hold true with DPR as well?
Unread 28-01-2012, 22:00
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: OPR Formula
I was not aware of this. Would someone be able to tap this data during the tournament to feed it into a scouting program? How much information is available there?
Also, I know OPR means offensive power rating, but what does this actually mean?
Unread 28-01-2012, 23:03
Re: OPR Formula
IIRC, OPR is the expected points contribution of any given robot to an alliance.
DPR... I don't think anybody's ever come up with a good way to calculate that. First you have to find a way to calculate a defensive score...
Unread 28-01-2012, 23:21
Re: OPR Formula
Couldn't you do it the same way Tom said he did the OPR, with the following twist?
Set up the equations like so:
red1+red2+red3 = blue_alliance_score
... then solve the system.
The lower the number, the better the DPR. Like golf.
Unread 28-01-2012, 23:34
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Re: OPR Formula
If you want to learn more about OPR, CCWM, DPR, PMR, please refer to
http://www.chiefdelphi.com/media/papers/2174
I will post an updated 2012 version of the presentation file shortly.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 29-01-2012, 00:07
Re: OPR Formula
Possibly. The hardest part about DPR is that a low blue_alliance_score could come from two possible sources. It could be that one or more red robots are playing really good defense. But, it could be that the blue alliance has a very low combined OPR (read: needs better offense even without defense being played). Without having an OPR-to-score comparison built in, there is no real way to determine whether red is playing good defense or blue is playing bad offense.
You might be able to do it with
red1+red2+red3 = blue_alliance_OPR - blue_alliance_score
and the higher the score the better (due to the OPR-score) but that involves knowing the blue alliance's combined OPR.
Unread 29-01-2012, 00:48
Ed Law's Avatar
Re: OPR Formula
Numerically, DPR = OPR - CCWM (calculated contribution to winning margin). A team will have high DPR if their CCWM is low or negative comparing to OPR. Low DPR means a team is good in defense. Basically it means they do not allow their opponents to score much.
I do not agree with low DPR is a result of opposing alliance's inability to score. Over a number of matches, those teams with low OPRs will also cause other teams to experience the same thing. A team's DPR will only be higher or lower based on how they perform on average comparing to other teams. Remember OPR, DPR and CCWM are all calculations of that team's calculated contribution.
[IMG] code is Off
