Go to Post All I have to say is --- Life == FIRST - Lora Knepper [more]
Unread 28-01-2012, 13:09
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
Two Digital Sidecars?
Hi all. My team is getting ready to do the electrical bits for our robot, and based on current design we need more than 10 PWM outputs. Thus, we need to know whether it is within the rules to use two digital sidecars. Any insight?
[R60] says "Every relay module, servo, and PWM speed controller shall be connected via PWM cable to the Digital Sidecar and be controlled by signals provided from the cRIO via the Digital Sidecar. They shall not be controlled by signals from any other source."
My interpretation of "the Digital Sidecar" is that we can only use one, but I am very interested in someone disproving my hypothesis.
I'm Bubba. I make noise, sometimes it comes out as music, and I love robots.
Unread 28-01-2012, 13:11
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Two Digital Sidecars?
We used two last year, I don't know of any rule stopping you.
I can't quote any rules regarding it though. If you can use two NI modules for two sidecars...
Also the electrical diagram has two digital sidecars.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 28-01-2012, 22:45
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I don't believe that it is illegal to use more than one sidecar.
Also, note that you can split a PWM signal to multiple Jaguars/Victors. I'm not sure about servos, since you are splitting a power supply, not just a signal.
Unread 28-01-2012, 23:39
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
It's fully legal to have a second Digltal Sidecar, it's accompanying DIO module would go in slot 4 on the 4-slot cRio or slot 6 on the 8-slot cRio.
As to why you would need that many PWM's, I will say:
-Small motors can run on Spike relays if you don't need variable speed control
-You can Y anything off of the DSC - I know of no technical limits to the number of splits.
-The servos/vex motor controllers use the 6v supply which can supply up to 3a. This should have no problem with several servos.
Kettering Motorsports
Unread 29-01-2012, 00:17
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Yeah a Y splitter pwm cable comes in the kit of parts.
Prototype, Prototype, Prototype
Unread 29-01-2012, 10:42
cgmv123's Avatar
AKA: Max Vrany
The kit drivetrain is designed to run off 4 CIMs. There are actually 2 of them and this is what they are intended for.
Unread 29-01-2012, 11:00
DonRotolo's Avatar
Back to humble
FRC #0832
...or at least one typical way of using them.
