Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 28-01-2012, 23:45
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
Gear ratio of CIM-U-LATOR for banebot-775
Can anyone tell me the gear ratio for CIM-LATOR banebot-775?
^^ this gearbox
Unread 28-01-2012, 23:48
Andrew Lawrence
Posts: n/a
Re: Gear ratio of CIM-U-LATOR for banebot-775
As said on the banebots website, it's a 2:7:1 reduction.
Unread 29-01-2012, 00:00
FRC #2935
it says
Reduction : 2.7:1
is 2.7:1 same thing as 2:7:1?
Unread 29-01-2012, 00:02
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by swapnil94 View Post
it says
Yes. it is 2.7:1 he made a typo. And you can always count the number of teeth on each gear. 27 tooth and 10 tooth.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2012, 00:04
Andrew Lawrence
Posts: n/a
it says
Yeah, typo. It's 2.7:1. For a single stage gearbox, it's hard to get 2:7:1.
Unread 29-01-2012, 00:10
FRC #2935
Ohh
so 19500 rpm would be geared down to 7800 rpm. right?
just making sure
thanks
Unread 29-01-2012, 00:12
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes.
Kevin Li
596 - Sciclones
Unread 29-01-2012, 00:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Ohh
just making sure
thanks
Oh and FYI, I'm pretty sure that the motor you are using is the RS775-18... If so then it only spins at 13000 RPM at 12 volts giving it about 4800 rpm out of the CIMulator.
Kevin Li
596 - Sciclones
Unread 29-01-2012, 01:37
Ohh
just making sure
thanks
Three problems:
1) The free speed of the RS550-12 is 19300. That's not the motor you are planning to use is it?
2) 19500/2.7 = 7222, not 7800.
3) RS775-18 free speed is 13,000 not 19500 13,000/2.7 = 4815
