Go to Post I suspect the GDC is enjoying watching teams wrap their heads around this ranking algorithm.... and is probably a bit surprised that it has taken teams so long to clue in to the options this ranking system presents to them. - dtengineering [more]
Unread 29-01-2012, 00:10
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
Re: Gear ratio of CIM-U-LATOR for banebot-775
Ohh
so 19500 rpm would be geared down to 7800 rpm. right?
just making sure
thanks
Unread 29-01-2012, 00:12
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yes.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2012, 00:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Originally Posted by swapnil94 View Post
Ohh
just making sure
thanks
Oh and FYI, I'm pretty sure that the motor you are using is the RS775-18... If so then it only spins at 13000 RPM at 12 volts giving it about 4800 rpm out of the CIMulator.
Kevin Li
596 - Sciclones
Unread 29-01-2012, 01:37
Ohh
just making sure
thanks
Three problems:
1) The free speed of the RS550-12 is 19300. That's not the motor you are planning to use is it?
2) 19500/2.7 = 7222, not 7800.
3) RS775-18 free speed is 13,000 not 19500 13,000/2.7 = 4815
