Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
Unread 28-01-2012, 23:45
swapnil94 swapnil94 is offline
FRC #2935
swapnil94 is an unknown quantity at this point
Gear ratio of CIM-U-LATOR for banebot-775
Can anyone tell me the gear ratio for CIM-LATOR banebot-775?
^^ this gearbox
Unread 28-01-2012, 23:48
Andrew Lawrence
Posts: n/a
Re: Gear ratio of CIM-U-LATOR for banebot-775
As said on the banebots website, it's a 2:7:1 reduction.
Unread 29-01-2012, 00:00
FRC #2935
it says
Reduction : 2.7:1
is 2.7:1 same thing as 2:7:1?
Unread 29-01-2012, 00:02
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by swapnil94 View Post
it says
Yes. it is 2.7:1 he made a typo. And you can always count the number of teeth on each gear. 27 tooth and 10 tooth.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2012, 00:04
Andrew Lawrence
Posts: n/a
it says
Yeah, typo. It's 2.7:1. For a single stage gearbox, it's hard to get 2:7:1.
Unread 29-01-2012, 00:10
FRC #2935
Ohh
so 19500 rpm would be geared down to 7800 rpm. right?
just making sure
thanks
Unread 29-01-2012, 00:12
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes.
Kevin Li
596 - Sciclones
Unread 29-01-2012, 00:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Ohh
just making sure
thanks
Oh and FYI, I'm pretty sure that the motor you are using is the RS775-18... If so then it only spins at 13000 RPM at 12 volts giving it about 4800 rpm out of the CIMulator.
Kevin Li
596 - Sciclones
Unread 29-01-2012, 01:37
Ohh
just making sure
thanks
Three problems:
1) The free speed of the RS550-12 is 19300. That's not the motor you are planning to use is it?
2) 19500/2.7 = 7222, not 7800.
3) RS775-18 free speed is 13,000 not 19500 13,000/2.7 = 4815
