Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Unread 29-01-2012, 01:59
Re: Swap D-link with old Linksys bridge for practice bot?
You mean the old square black bridge?
It's only a wireless bridge, not a wireless access point. You can't connect a WiFi-equipped computer to it directly; you need a true access point like the blue wireless router that was also supplied the years the black bridge was used. So it can be done -- the TechnoKats do it regularly -- but it requires some fixed infrastructure.
However, you can put the wireless router on the robot and connect the Driver Station computer to it in exactly the same way it connects to the white D-Link. The Linksys routers I'm familiar with use exactly the same power connector and exactly the same voltage as the Linksys bridge.
