Go to Post While many teams like to go fast, only a select few do it well. - Al Skierkiewicz [more]
Unread 28-01-2012, 19:41
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
The CyberHawks 2012 ride
Here is how 706 is rollong this year.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 28-01-2012, 20:00
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: The CyberHawks 2012 ride
Very nice! Wish we were that far ahead >.>
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 28-01-2012, 20:45
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Weight?
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 28-01-2012, 22:59
Bruceb's Avatar
Currently 53 lbs
Bruce
Unread 28-01-2012, 23:15
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
your chassis is 53 lbs with nothing on it... and you aren't worried???
cole?
Unread 29-01-2012, 10:04
Bruceb's Avatar
Nope
Unread 20-02-2012, 13:12
Bruceb's Avatar
Well she is all up and running now and weighs in at 119.5.
I'll post a pic later.
Unread 20-02-2012, 20:33
Bruceb's Avatar
Here is a video link of our 2012 ride
http://s1121.photobucket.com/albums/...t=100_0013.mp4
Bruce
Unread 21-02-2012, 10:01
Bruceb's Avatar
OK some details
Drive:
4 CIMS on super shifters with the standard ratio driving 6 AM pneumatic wheel/tires 1/4 in center drop that can be tuned with tire pressure
Bridge manipulator
pneumatically actuated ramp with over center latches so the force of the bridge is not transmitted to the very small pneumatic cylinders
Ball handling
High speed intake roller separate from the conveyor powered by an RS550 driving through a custom FP geared gearbox at about 9-1 reduction and connected to the rough top covered roller through a small v-belt that can be adjusted for slip if need be.
Door motor powered conveyor running 4 loops of polycord to hold up to 3 balls. Ball position sensed with IR sensors and micro switches.
Feed rollers at the top of the conveyor powered by the same configuration as the intake roller less the v-belt. These "feed" rollers consistently toss the ball up to the shooter rollers and give separation from the balls still in the conveyor.
The shooter consists of two 6 inch grey AM wheels sanded to an angle to match the ball and powered by 2 FP 9015 motors with 4-1 belt driven reduction.
Distance is calculated with the axis camera and controlled through a pid loop spinning the shooter wheels.
The hood has only 2 positions, one for scoring and one for feeding from defense.
Hood rotation is controlled by a window motor through laser cut acetyl gears and feed back is given through a 10 turn pot for close to 360 degrees of rotation.
Low CG for easier and proven balancing.
See you in Milwaukee and ST. Louis.
Bruce
Unread 22-02-2012, 10:37
Bruceb's Avatar
What no comments. Are we being shunned?
Come on
What do you think?
The low CG makes us great at balancing. Did it in all but one match at our mini regional last Sunday. Even did the coopertition balance once.
Comments?
Thanks
Unread 22-02-2012, 10:43
barn34's Avatar
barn34 barn34 is offline
Isn't this how Skynet got started?
AKA: William Barnickel
FRC #2481 (Roboteers)
barn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond repute
Looks good, guys! Quite a few of your features are very similar to ours, which means we really like what we've seen. Do you know the range on your shooter? Looking forward to seeing you in Milwaukee, and hopefully getting an opportunity to team up again and avenge that heartcrushing loss from the 2010 finals...or, at the very least, we'll gladly join you on the coopertition bridge.
Unread 22-02-2012, 11:28
Bruceb's Avatar
I've seen the shooter push 28 ft.
Bruce
Unread 22-02-2012, 13:05
barn34's Avatar
Sweetness. We were shooting from somewhere around that distance last night, as well. That's right on the other side of the bump, correct? We were also taking shots from on top the coopertition bridge. Accuracy was only about 1 out of 5 or so from there and was very dependent on how stable the bridge balance was, but that's still a 20% chance of doing something that would be pretty epic in a qualifier if we have the opportunity.
I say, if we we happen to be paired opposite in a qualifier, we both try to simultaneously take a shot from the coopertition bridge together as the match ends.
Unread 22-02-2012, 14:23
Bruceb's Avatar
Now THAT would be a crowd pleaser !!!!!!!!
Bruce
