HELP: No Data Sent Back to Driver's Station
HELP! No data is showing up on the drivers station. The drivers station says that we are communicating with our robot (which is working) but no voltage indications or sensors are showing up! Has anyone else encountered this problem? What do we do?
Re: HELP: No Data Sent Back to Driver's Station
You're saying that the robot moves as commanded, but the Driver Station is not showing the battery voltage? That could be as simple as a missing jumper on the Analog Breakout connected to the cRIO module in slot 1.
I don't know what other sensors you are referring to. Can you be more specific about what you expect to see and what you're seeing instead? |
Sorry it appears that this was accidentally double posted, see this thread.
