Go to Post ...trapping Chuck Norris is worth infinity, Dave, Dean, and Woodie are 500 apiece, and trapping Andy Baker is worth double infinity - EricH [more]
Unread 29-01-2012, 11:46
That Canadian That Canadian is offline
FRC #0346 (RoboHawks)
That Canadian is an unknown quantity at this point
Display processed images on dashboard.
I'm currently able to process images and mask them etc. but I can't seem to figure out how to display the processed image on the dashboard (or possible on a separate frame). When I try to use the JFrame or Frame classes I can't get the imports (help on this would be appreciated) nor can I figure out how to display custom images on the driver station dashboard. I just need a way to display a custom image, thank you.
Unread 29-01-2012, 11:53
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
Re: Display processed images on dashboard.
I have the same problem. I think that the camera is tracking the squares but when i point the camera away from them, I still gives a reading. I want to print the images the robot sees after it has done its edge detection.
Unread 31-01-2012, 21:46
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
You can save your images onto your cRIO and the FTP into the cRIO to retrieve them. use the write method in BinaryImage and it will write the image to the root directory.
BinaryImage image;
image.write("test.jpg");
I believe that's the correct syntax
To FTP into the cRIO type ftp://10.te.am.2 into your browser and then you can retrieve the pictures.
