Go to Post Its a good idea to learn to tame CAD monkeys. They're very useful. - Akash Rastogi [more]
Unread 28-01-2012, 15:36
Varriount Varriount is offline
FRC #2421
Varriount is an unknown quantity at this point
Questions on WPILib components thread usage
Hello, my team has just started programming in java, and we've studied the documentation of WPILib, however some of us still have questions regarding thread safety and thread usage of WPILib's components.
What, if any, components of WPILib use threads? (Not including java's native thread library)
Does the VM on the cRio do any sort of automatic background threading or threading without the explicit usage of thread objects, in such a way that we would need to ensure the thread safety of our code?
Unread 28-01-2012, 18:26
Chiller Chiller is offline
AKA: Connor Christie
FRC #4095 (RoXI Robotics)
Chiller is on a distinguished road
Re: Questions on WPILib components thread usage
Yes, all screw holes are threaded.
Unread 29-01-2012, 12:29
FRC #2421
Um, excuse me? Chiller, could you clarify?
Unread 29-01-2012, 15:00
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Digging through the WPILIBJ source code, I can see a couple of threads created, but only for minor asynchronous communication. Preferences, for instance, are saved and retrieved in a separate thread. Some of the networktable methods manage connections in separate threads.
The actual robot code seems to run entirely in a single thread.
Thread-safety is a good topic to discuss and an important discipline to remember, but I think that it will not be an issue in your robot code.
Unread 29-01-2012, 15:20
FRC #2421
Thanks for the information krieck. It's one less thing for our team to worry about. What about the command system? One would think that to run commands synchronously, they would be run in a seperate thread?
Unread 29-01-2012, 16:12
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
They are not, instead commands are just run in order in a single thread. Because of the iterative nature of commands though, this makes the run concurrently.
However, there is a downside because if one of your commands calls sleep or whatnot in its execute method, then all the other commands will have to wait for yours to finish before they do anything.
Unread 29-01-2012, 16:45
Did you mean concurrently?
Unread 29-01-2012, 16:47
FRC #2421
Ah, yes, I did mean concurrently, sorry.
