Go to Post I'd hate to state the obvious here...but I believe that we all just got Rick-rolled... - Hallry [more]
Unread 29-01-2012, 12:47
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
HELP!!! No data being sent back to the drivers station!
HELP! No data is showing up on the drivers station. The drivers station says that we are communicating with our robot (which is working) but no voltage indications or sensors are showing up! Has anyone else encountered this problem? What do we do?
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 29-01-2012, 13:28
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
Re: HELP!!! No data being sent back to the drivers station!
You can get voltage readings by putting a jumper on the outer two pins of the analog breakout on the cRIO. As far as output to the dashboard, you can customize the dashboard yourself to get specific data, there are tutorials online for such.
However, getting the built in lights and indicators to work is another matter. My team's don't work, so I can't advise you as to how to make them functional.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 29-01-2012, 17:53
The Build Dashboard Data vi in the default robot project has a bug in it. There is an extraneous increment that needs to be removed in order for the feedback to the dashboard to work properly.
https://decibel.ni.com/content/thread/11668?tstart=0
Unread 29-01-2012, 20:59
I am aware of the jumper and it is on, it's not just the battery info thats not being sent back to dashboard, nothing is showing up on the dashboard, like the GPIO states, the relay states, the pwm readings, the solenoid states. However, the robot is functioning, meaning when I push a joystick the victor light changes color as it should and compressor and sensor are working.
Unread 29-01-2012, 21:02
This does seem to be our problem, I will take a look tomorrow.
