Go to Post The true beauty is, no matter what the game (Yes, even 2001), we spend these 6 weeks going crazy with design strategy, and trying to figure out a way to work the plot twists that the GDC throws at us...and its a blast. - Andy Grady [more]
Unread 29-01-2012, 14:51
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Red Light Crisis on Spike
Hi
We are using pneumatics on the robot and we have all the components ready. Compressor piston solenoid air tanks and spikes. When we hit the button on the joystick in order to start the piston the spike connected to the piston flashes red. But I know that it should be green. What can be done to solve it ? Any ideas ?
Unread 29-01-2012, 15:56
HansJ's Avatar
HansJ HansJ is offline
AKA: Hans
FRC #3018 (Nordic Storm)
HansJ is on a distinguished road
Re: Red Light Crisis on Spike
I believe the light color depends on the direction of the output voltage. Does the compressor turn on?
2013 Lake Superior Excellence In Engineering Winner
2013 Lake Superior Dean's List Finalist
2013 10,000 Lakes Engineering Inspiration Winner
2013 Championship Creativity Award Winner
Unread 29-01-2012, 16:13
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
[quote=cilginbilgin;1115893start the piston the spike[/QUOTE]
The way you phrase that, it makes it seem that your have the pneumatics cylinder is wired into the spike?
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 29-01-2012, 16:20
FRC #2905
We have a solenoid valve that is wired to the spike.
Unread 29-01-2012, 16:30
AKA: Pat Miller
Ok well there's your problem. The solenoid valve needs to be plugged into the solenoid break out on the crio.
and I highlighted cylinder because calling it a piston is a pet peeve of mine. lol
Unread 29-01-2012, 16:34
AKA: Pat Miller
Oh and depending on what kind of valve it is 12v or 24v. it needs the proper wiring.
Unread 29-01-2012, 16:43
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
You can drive a 12 V solenoid valve with a Spike relay. You can even put multiple solenoid valves on one relay:
[R46]
Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator, electric solenoid, or compressor).
Exception: Multiple low-load, pneumatic solenoid valves or lights may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions or multiple lights. No other electrical load can be connected to a relay module used in this manner.
Is the light flashing or solid? A solid red light means the relay is set to reverse. To set it forward (green light) you need to change the direction of the relay in your code. What language are you using?
EDIT - Seems the OP is trying to use a 24 V solenoid. In that case, you have to use the solenoid breakout. And you do not connect a Spike to the solenoid breakout; you connect the solenoid valve directly to the solenoid breakout. If you want to use a Spike to drive a 12 V solenoid valve, you connect the Spike to the digital sidecar, never to the solenoid breakout.
Go directly to queue. Do not pass pit.
Unread 29-01-2012, 16:47
FRC #2905
Question Re: Red Light Crisis on Spike
I will start from the very beginning.I have a solenoid valve that is wired into the spike.
Here is the valve that we use.
http://www.festo.com/rep/en-us_us/as...ions_2011b.pdf
Then I wired the pwm output of the spike to 2 ports on the solenoid breakout.
Unread 29-01-2012, 16:48
AKA: Pat Miller
Well I didn't know that thanks. I just find it easier to use the break out. It saves space.
Unread 29-01-2012, 16:52
AKA: Pat Miller
Well thats a 24v and it has to go to break out and that pictures seems to be wired wrong.
Unread 29-01-2012, 17:04
FRC #2905
But there are lights on both corners of the valve.
Doesn't this mean that valve is powered correctly ?
Unread 29-01-2012, 17:06
FRC #2905
Here is our code.
ID:	11624  Click image for larger version
Unread 29-01-2012, 17:11
AKA: Pat Miller
Not quite, On one side of the valve power and ground need to come from the PD and the other side goes to the ground and power side of the spike (M+, M-).
But if it is a 24v valve, it needs to be wired to a 24v breakout. It will only get 12v for a spike.
Unread 29-01-2012, 17:18
Al Skierkiewicz Al Skierkiewicz is online now
cil,
When you use a 24 volts solendoid valve, the only legal and correct way to use it is to wire the solenoid module in the Crio for 24 volts. There is a wiring diagram on the First website to assist you. I believe you can find it in the KOP section. The Spike can only control 12 volts. While some people have reported that their 24 volt valves work on 12 volts, they are not reliable at that voltage.
Unread 29-01-2012, 17:20
FRC #2905
So what you are saying is don't wire the spike with the valve , just wire the valve to the solenoid breakout ? OR...
