Re: Code download stops at FTP step
After you upgrade the cRIO you have to manually restart it to get the FTP server working.
If that doesn't work... Use the re-imaging tool to check the IP of it, and make sure it matches the one in your Driver Station settings and Netbeans plugin settings. And if that doesn't work... Have the Driver Station automatically configure your network settings for you using the "Choose NIC" button. |
