Go to Post I was hoping they'd be selling robots. - Tristan Lall [more]
Unread 29-01-2012, 13:37
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Turret/Tower Height
Hey teams. just wondering where you find the sweet spot as far as the height of your shooter tower. First, Are you using a spinning turret or a tower with a spinning shooter?. How many degrees does it turn, if it does at all? Finally, how tall are you guys making your tower? I figure it doesnt need to be more than a foot of tower space, but then again maybe some people are storing balls in the tower. What do you guys think?
Unread 29-01-2012, 15:20
n1ckd2012's Avatar
n1ckd2012 n1ckd2012 is offline
oRyon Labs
AKA: Nick Dulworth
FRC #2587 (DiscoBots)
n1ckd2012 will become famous soon enoughn1ckd2012 will become famous soon enough
Re: Turret/Tower Height
Our shooter axel is 50 inches from the ground. Not sure if there is a sweet spot. We are tall so it's harder block our shots. Shooter has tiltbut no turret.
More details at 2012.discobots.org. Link to our daily log is at the bottom of the page.
Ri3D Team oRyon, 2014-Present
Ri3D 2015: Betelgeuse | Ri3D 2014: Draconis
2587 DiscoBots, 2010-Present
FRC 2012: Laser Dragon, Film, Build Log, Lone Star 3rd Seed Alliance
Vex 2012: Mini Dragon, Film, Math Division Finalists
FRC 2011: DiscoSlide, Film, 118 Parody, Lone Star Regional Finalists
Unread 29-01-2012, 16:42
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We put ours at 24" to make balancing and going over the barrier easier. If we go to the back of the key, we can't be blocked and we saw no reason to shoot from anywhere else.
Unread 29-01-2012, 16:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How do you figure?
Unread 29-01-2012, 17:04
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
[quote=n1ckd2012;1115915]We are tall so it's harder block our shots.
QUOTE]
That's not neccesarily true. You could have a tower that's low to the ground and be right up against a taller robot, and all you have to do is just change the angle. The thing you need to take into consideration with the height of the tower is how that affects the center of gravity. You need to make sure its low enough for traversing the bump and/or bridge (if you're doing either). Low cg's will come in especially handy when trying to balance. I'd say a heigh of 30 or 40 is good. That's what we've got.
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 29-01-2012, 20:20
AKA: Simon Bohn
Originally Posted by squirrel View Post
How do you figure?
The trajectory that we fire at ensures that the ball is above 60" by the time it hits the front of the key.
Front being defined as the part closest to the baskets.
Unread 29-01-2012, 20:24
DonRotolo's Avatar
Back to humble
FRC #0832
How do you figure?
We'll do it one better: The ball is above 60" by the time it reaches the vertical projection of our bumper. If we're touching the key, no reasonable defense strategy is going to see an opposing robot "bump" us, so we *hope* that'll do.
Our shooter's top is around 50" as well.
Unread 29-01-2012, 20:45
MrForbes's Avatar
AKA: Jim
An opposing robot is allowed to be on your key (and block your shot, if your shooter is low). They receive a foul if they contact you while you're on the key.
I guess you could assume that no other robots will try to block you while you're on the key, but that may or may not be a valid assumption.
Unread 29-01-2012, 21:51
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
In my opinion this is a pretty safe bet, they could just drive forward quickly and they'd get the foul. In fact, tempting opposing robots to sit in front of you in the key could be an even better scoring strategy than sinking baskets .
Unread 29-01-2012, 22:21
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
Hey teams. just wondering where you find the sweet spot as far as the height of your shooter tower. First, Are you using a spinning turret or a tower with a spinning shooter?we have a spinnining robot. How many degrees does it turn, if it does at all?it can turn 360 Finally, how tall are you guys making your tower?we will not have a "tower" I figure it doesnt need to be more than a foot of tower space, but then again maybe some people are storing balls in the tower. What do you guys think?i think your robot will fall over the first time you shoot a ball.
why are you so obsessed with spinning towers?
cole?
Unread 01-02-2012, 15:58
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
jon-s is an unknown quantity at this point
We're avoiding a turret because we'd heard that during the 2006 competition, drivers would get confused by the driving chassis and turret turning independently (using tracking systems). It's also more complication that is not necessarily needed.
I think the main danger with towers is that they can whip around on the bridge, when crossing the barrier, or when your robot is hit by other robots (and can then break off without a significant amount of bracing). They also alter the center of gravity quite a lot. While you may not fall over when shooting, a robot with a tower possibly may when crossing over the barrier (especially when hit by another robot) or more likely, when crossing the bridge.
Our shooter is about 28-30in high right now. We've configured the shooter so that it can't be blocked by other robots. It is still vulnerable to being rammed.
We're aiming to be able to shoot from several places on the field.
Jon. S
Unread 01-02-2012, 18:04
Tylernol's Avatar
Tylernol Tylernol is offline
FRC #2993 (MegaBots)
Team Role: Marketing
Tylernol is an unknown quantity at this point
Our shooter is a one wheel design with the axle mounted at 36 inches high. We're using a small amount of vertical space plus the angled space from the front of the bot to the back (Where our shooter is located) to store the balls.
Unread 01-02-2012, 18:07
waialua359's Avatar
waialua359 waialua359 is online now
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Doesnt most teams have one student driving the robot and the other working the controls?
Unread 01-02-2012, 22:59
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FIRST Team 1296 is at 52" - also seems safe to me
Unread 01-02-2012, 23:26
AKA: Simon Bohn
If they do try this, we can drive forward and bump them, under no penalty to us, and a three point penalty to them.
