Go to Post FIRST is like we have traveled to the future, and we dont like what we saw when we got there. So we came back and now we are attempting to alter the future - KenWittlief [more]
Unread 29-01-2012, 16:06
Team4014 Team4014 is offline
FRC #4014
Team4014 is an unknown quantity at this point
Exclamation How would we program in a Logitech gamepad controller into LabVIEW?
We want to be able to use the Logitech F310 controller to drive our robot with tank drive (using the Y axis of each joystick on the controller to run their respective drive motors on each side of the robot), and we can't figure out how. All of the things we've found online are for the Attack controllers, and use two USB ports rather than 1. Any help would be much appreciated.
Unread 29-01-2012, 16:30
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
Re: How would we program in a Logitech gamepad controller into LabVIEW?
In Labview, the programmers should use Unbundle By Name for the axes wire of the Get Joystick vi, or use the Get Axis vi and use axis 2 and axis 4, these are the Y axis of the two main joysticks.
Unread 29-01-2012, 17:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The Logitech F310 has the following axis mapping on a single USB port: (this is exactly the same as the Xbox 360 gamepad, for reference)
Axis 1 - Left X
Axis 2 - Left Y
Axis 3 - Sum of L2 and R2 triggers - One is positive, the other is negative, both or none is 0
Axis 4 - Right X
Axis 5 - Right Y
Axis 6 - D-Pad Horizontal - One direction is +1, the other -1. You can't read the vertical axis
Please note that mgurgol is not correct entirely, axis 4 is NOT right Y on the F310 (it is on the DualAction).
Kettering Motorsports
Unread 29-01-2012, 17:28
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Our team used this last year during two events without any issues:
http://www.chiefdelphi.com/forums/sh...ad.php?t=90022
Major thanks to Alexander Meyer on team 2358.
Unread 30-01-2012, 11:57
FRC #1094
My apologies, I was thinking of the Dual Action.
Unread 30-01-2012, 15:14
In LabVIEW, it's very easy to see which controls on the gamepad are associated with the various buttons and axes. Just attach indicators to the existing Joystick Get in Teleop. Run the Robot Main vi and look at the Teleop front panel as you play with the joystick.
Unread 06-05-2012, 11:44
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Cool Re: How would we program in a Logitech gamepad controller into LabVIEW?
I still dont understand how to use the two mini-joysticks on the F310 gamepad as a tank drive.
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 06-05-2012, 12:05
Axis 2 is the left Y axis. Axis 5 is the right Y axis. Use those as the inputs to a standard tank drive function.
Unread 06-05-2012, 12:32
2185Bilal's Avatar
AKA: Bilal Majeed
Post Re: How would we program in a Logitech gamepad controller into LabVIEW?
Ohh Thanks, but what was the other post u posted Jw
RAMAZOIDZ
