Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 28-01-2012, 15:00
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Help Improving Bridge Acuracy
My team got finished building some cheaper versions of the bridges, but just like everyone else that has done this, we are having problems making the bridges accurate. I've heard you can put 50 lbs. on either end to make it work, but i'm not sure where on the bridge that would go. Does anyone know what we need to do?
Thanks
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 28-01-2012, 15:05
Billfred's Avatar
Billfred Billfred is offline
Re: Help Improving Bridge Acuracy
Thanks
Assuming your bridge won't see heavy testing, the natural suggestion would be to mount weight wherever the other end of the bridge will pass the two-battery test.
However, the one bridge I've seen in person was built to the drawings and passed the test until excessive testing pushed the double-hinge out of spec, throwing the balance of. Are you working off of FIRST's team drawings, or are you estimating it yourself?
Unread 28-01-2012, 15:08
Flimsor's Avatar
The Mad Cadder
Alright we'll try that.
- 2013
Robots
Unread 29-01-2012, 01:58
Flimsor's Avatar
The Mad Cadder
Any ideas on what to use as weight and how to mount it? Also about where have you noticed the weight goes (just so we don't have to spend so much time finding the general area ).
- 2013
Robots
Unread 29-01-2012, 09:27
Billfred's Avatar
At the risk of sounding unhelpful, the answer is "wherever it means your bridge passes the two-battery test." Without knowing your bridge (even in the face of FIRST's drawings for teams), it's not really possible to answer much better.
Unread 29-01-2012, 17:27
It is the center of mass of the weight that matters. To have an appropriate effect, it should be centered between and above the hinges.
Unread 29-01-2012, 20:48
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The problem of getting your team field bridge to behave like the ones you're going to see in competitions is a combination of statics AND dynamics. *just like life* If you position some weights on the other side of the fulcrums so that the battery balance test is passed, you will be dealing with the static difference of your bridge. You should be able to figure out some things about how to deal with bridges, like how hard to push on one edge to get it low enough to drive onto, for instance.
If you want to practice balancing on your bridge, the rotational inertia about the hinge points will become important. So the distribution of the weights you applied to achieve the right static balance will be factors in how the bridge reacts to your fast or slow driving back and forth across it. The reason tight-rope walkers carry a pole is to increase their rotational inertia and decrease the effect of small errors in their walking balance.
You can make the bridge behave statically correct by weights of different amounts at the appropriate distance for each. The chance that it will behave dynamically the same as the metal one is yet to be determined. And we haven't even stopped to consider the hinge friction characteristics under varying loads.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 30-01-2012, 11:58
Sumathi's Avatar
Sumathi Sumathi is offline
FRC #2410 (The Metal Mustangs)
Sumathi is an unknown quantity at this point
The way you can test your bridge is through the two battery test. If I remember correctly FIRST had a youtube video demonstrating the test. They also told you how far apart the batterys should be placed. I would put the link up, but I am currently in my Econ class and youtube is blocked in our school.
Oh, KISSing is so fun! Don't forget to Keep It Super Safe, and share the love.
