Go to Post Ask not what FIRST can do for you but what you can do for FIRST. - Koko Ed [more]
Unread 29-01-2012, 20:12
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
Exclamation Ni Vision Help???
Hello every one a mentor and i have been having major issues with the c code generated by the NI vision software to run our target tracking. we have edited the code so many times and taken it apart and dissected it looked it over and we have spent the past few days on this with no luck has any one else had issues or luck with this thanks every one for your help in advance.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 29-01-2012, 20:15
Re: Ni Vision Help???
I don't know that we can be of much help without seeing the code. The NI Vision Assistant is a general tool used in industry to create prototype code. It should work, but definitely doesn't contain the camera specific code and won't contain some of the math for scoring particles (or whatever you are using the differentiate the particles).
Greg McKaskle
Unread 29-01-2012, 21:14
splatter's Avatar
AKA: Robert
Team Role: CAD
thanks for and i will talk to my mentor tomorrow about posting the code.
FIRST Team 271
<Electrical, CAD>
Unread 30-01-2012, 09:54
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Are you compiling the generated code as a c or cpp file. By default the code generator outputs a c file, and I had some nasty issues trying to compile it as such.
I changed the extension to .cpp to compile it in C++, after that the majority of the errors cleared up, and there were just a few casting issues to resolve. This post has a bit more detail about what I did:
http://www.chiefdelphi.com/forums/sh...d.php?t=101222
Hope this helps, I'm still having issues getting this fully working, but getting closer
Unread 30-01-2012, 15:54
splatter's Avatar
AKA: Robert
Team Role: CAD
thanks for the response i will have to mention the .cpp to my mentor thanks for the reply i will let you know if it worked
FIRST Team 271
<Electrical, CAD>
Unread 31-01-2012, 21:44
gnichols gnichols is offline
FRC #3862
gnichols is an unknown quantity at this point
How are you getting the C code out of the Vision program? When I try to create the code it says
This feature is disabled in the evaluation mode, please purchase the product.
It tells me I am using an invalid serial number when I enter the number used to validate the other NI software.
Unread 31-01-2012, 22:11
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
we had a hard time exporting it to labview from the vision assistant as well, it either gave us the eval version error, or just brought labview to the foreground, and didn't actually create any VIs.
However, each 'step' in the Vision assitant you create, matches up with a VI from the vision palletes, so we just made the sequence ourselves, with the values we discovered using the vision assistant.
Unread 01-02-2012, 14:12
Programming Mentor
AKA: Joe S
I'm not well versed in how the licensing works, but you should try calling national instruments (I've heard they are quite helpful); as they should be able to get you a new license key if you have a bad one.
