Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 29-01-2012, 21:42
zekrysis zekrysis is offline
FRC #3616 (Phenomena)
zekrysis is an unknown quantity at this point
Re: How to view inputs and outputs in LabVIEW once code is deployed to robot
If I'm not mistake couldn't you also simply right click on the little wire out node and click create indicator?
Unread 29-01-2012, 22:13
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
Yes, you could do that, but the most appropriate option would be to right-click the wire and select Probe. It's designed for showing real-time values.
This only works when you run the code by hitting Run in Robot Main through the computer. There is no way to probe your code if you run it by building it and 'running as startup'. (that is, except for what you put in the dashboard)
