Go to Post The biggest thing is you don't have to make your robot like another teams. Come up with something unique and go from there. RAISE THE BAR..... - camtunkpa [more]
Unread 26-01-2012, 21:55
jbachmann96 jbachmann96 is offline
FRC #2659
jbachmann96 is an unknown quantity at this point
Question 2012 image, E09 FRC
Hi i have flashed the driverstation netbook and now there is no operating system what do I do now. do i have to do a certain setup or special OS.
Unread 26-01-2012, 22:58
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: 2012 image, E09 FRC
An operating system is copied to the Classmate from the USB Stick labelled E09, if done properly.
Can you explain what you have done?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 30-01-2012, 00:28
FRC #2659
well i booted from it and it loaded fine and it asked me if i wanted to erase everything to reflash the classmate and i said yes and it asked me if i was sure and i said yes again and it did this little process and now when i boot it it says bootmgr missing.
Unread 30-01-2012, 00:31
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
Try rebooting with the flash drive again, and running the Win 7 installation. we had a similar problem, and this cleared up.
Unread 27-01-2014, 10:38
Mr. Dnp Mr. Dnp is offline
FRC #3863
Mr. Dnp is an unknown quantity at this point
Unfortunately after an initial try in Jan14 on one of our older E09EI6 models, using the E09_DRV image download from the 2014 (corrected 030114") Intel image download site, I never even saw a Win7 installation. I don't seem to be able to boot from the NTFS USB drive created using the supplied "RMPrepUSB". Every try I get the same "BOOTMGR is missing" then CR-LF and "Ctrl-Alt-Del to restart" on next line. If I try to boot to the hard drive I get a full screen with information about doing a Windows restore. The 'RMPrepUSB' creates a folder on USB 'E09_DRV_2014_030114'. This folder has a number of files and subfolders. One of the top level files is 'bootmgr'.
Seems like a bootable USB and full image should eliminate the need for restore, however I haven't had any luck producing a USB that the E09 will boot from. I've tried several different settings in 'RMPrepUSB', still no luck.
Anyone had better luck with this? I'm going to try the CTL liason, they've been pretty responsive via chat.
