Go to Post If you cannot complete relatively simple tasks, why would anyone assign you something more challenging?? - Chris Fultz [more]
Unread 27-01-2012, 23:18
Re: Spining wires? cRIO mounting?
Shaun,
When you don't let the wire twist naturally, the strands inside tend to twist to the point of breaking and force their way to the surface of the insulation. You might get lucky and then again, you might not.
Unread 28-01-2012, 22:30
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
We made our electrical board out of 2 pieces of Lexan sandwiched together. We zip-tied most everything else but bolted the cRIO down. It was hard to get the zipties through the modules. 11 pounds when all was said and done. Note to self, replace the nuts with locking nuts tomorrow. After that, on to not making the cabling a rat's nest.
Unread 28-01-2012, 23:54
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
cgmv123 - Why two pieces of Lexan?
You want to make sure your cRio is mounted securely no matter what... it's expensive to replace, and a huge brick with a lot of momentum. Remember when mounting it, however, than the bolts you use to mount it to the lexan (or wood, or whatever your electrical board material is made out of) are likely to be electrically conductive as well - if those bolts them hit your frame or a bottom pan in your robot, the cRio will be grounded to the chassis (which means you'll fail inspection until you correct it). So make sure you get some good backing there or cut holes to ensure those bolts aren't touching anything metal other than the cRio!
Unread 29-01-2012, 10:38
cgmv123's Avatar
AKA: Max Vrany
We only had quarter-inch thick Lexan handy, so we sandwiched 2 together for extra support.
And the Lexan automatically isolates the cRIO, so we are set there as well. The Axis Camera is a different story.
Unread 29-01-2012, 17:50
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
What is the stroy with the axis camera i know how to wire it but mounting it? ?
Unread 29-01-2012, 17:54
The camera, like the Crio has a metal chassis that is tied to the negative lead of the battery. The camera, when used, must be insulated from the robot frame.
Unread 29-01-2012, 18:16
Shaun Coon's Avatar
FRC #2487
So you reccomend putting it on a piece of lexan
Unread 29-01-2012, 21:11
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Shaun Coon View Post
Ok so i will through bolt the lexan through the 80 20 and i dont have a partner holding the other end i put it in a vice and one done put zip ties on each end after i cut the part that was in the vice and in the drill so there is no chance for damaged wire.
Shaun,
Shaun,
I understand how you want to twist those wires, and I admire your understanding that the wires could get damaged. This is good. Also, I agree with everyone who says that it is perfectly legal to twist the wires.
A better way to twist wires together is to kind-of braid them. When you just spin them with a drill, each wire twists inside itself too, and that's not as good for the wire. I know it is a little harder to twist them by hand, but it is better for the wire.
To twist wires the right way, put one end in a drill and start it spinning. Have someone else hold the single wires loose, in a "V" shape as they twist together. This YouTube video shows a guy using a machine to do this, but you can do it by hand too.
If the wires get twisted inside, which happens when you use a drill and vise, they can break inside (even in the middle of the wire) where you can't see and then you have real problems.
Unread 29-01-2012, 21:14
DonRotolo's Avatar
Back to humble
FRC #0832
You can put it on anything else that won't conduct electricity. The metal case of the camera, and of the cRio, both MUST be insulated from the metal chassis of your robot. Inspectors WILL check for this and make you fix it before your robot can compete.
Lexan doesn't conduct electricity, but also wood, rubber and other things might be good choices too.
Unread 29-01-2012, 21:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
How about mounting the cRIO (to metal frame) with a rubber gasket and nylon hardware? Crazy?
Unread 29-01-2012, 23:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Originally Posted by DonRotolo View Post
Shaun,
Alternatively, you could use some fishing swivels and fishing line to hold the wire for you, just be sure to wear your in case the line decides to break.
Unread 30-01-2012, 08:05
This would work but the nylon hardware might not hold in this year's wild game.
Unread 04-02-2012, 20:41
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Agreed - we mounted to lexan and lexan to the frame.
Unread 05-02-2012, 13:15
Nathan4567a's Avatar
Nathan4567a Nathan4567a is offline
Circuit Master
AKA: Nathan Lerner
FRC #2587 (Discobots)
Nathan4567a will become famous soon enoughNathan4567a will become famous soon enough
Since you are worrying about the visual appearance of the robot, I would not recommend spinning the wires. Instead, go to your local electronics store and buy wire with an outer casing. It makes everything look nice and neat, and in some stores, you have a choice of colors, so you can chose the wire to match the color of your robot. You will also have a choice of how many wires you want in the bundle, so that will eliminating having to run several strands side by side. We use these wires on our robot and they make it look great, and neat.
Unread 05-02-2012, 18:14
AKA: Alan Wells
FRC #1350 (Rambots)
Mind [R44] and [R45]. Power wires for the cRIO must be 20 AWG or larger (per [R44], and the positive must be red, white, brown, or black with a stripe for the +24volt side and blue or black for the negative side.
There are no restrictions on color for wire management devices such as spiral wrap and cable carriers, however I don't know if a casing such as the one shown is in the same category. That might be one for Q&A.
