Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 30-01-2012, 09:07
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Re: Spike motor control
Al: why can't we control an FP with a Spike? current?
Unread 30-01-2012, 11:37
fovea,
The robot rules restrict the CIMs and FP motors to speed controllers only. I however, recommend that teams be very careful when choosing what devices to use. The Spike is only designed to switch 20 amps, based on the specifications of the relay contacts used. However, several other motors have high stall currents as well. Some of the Banebots, AndyMark and possibly even an ARA motor since we have no specs on what motors teams may find all have higher stall currents than should be used with the Spike. While the Spike has worked for years in controlling the compressor, the old one only draws 25 amps for a short duration during start and then falls to 12 amps. The new compressor is just a little less. It is for this reason on the compressor Spike only, can the fuse be replaced with a 20 amp breaker.
Spike to CIM Motor Zultraranger Electrical 6 03-02-2010 17:20
Globe motor to spike controller stephenthe1 Motors 25 19-02-2006 23:03
Spike Control Line Signals Venkatesh Electrical 11 27-06-2005 07:23
Motor Question- Victor/Spike? 1166 Motors 10 16-02-2004 16:57
