Go to Post There's the problem!! The #1 reason to blame the programmers: They always forget to grease their code. :rolleyes: - Jack Jones [more]
Unread 30-01-2012, 11:04
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Painting Regolith?
We have the same material on some of the panels we use at my job and paint will stick to them. If I remember correctly they scuff the surface of the panel and use primer before painting and it seems to come out okay. (If you want the exact process I can find out)
-Dustin Benedict
Unread 30-01-2012, 11:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Krylon makes "Fusion for Plastics" haven't tried it myself though.
Unread 30-01-2012, 13:23
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Yeah Krylon is some of the best paint for plastics. I'd recommend running a sander over it to rough up the surface a bit, then apply it in light, even coats, and add more than 1 coat.
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 30-01-2012, 18:40
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
I keep threatening to put some panels of it on our robot instead of polycarb and make first year students put speed holes in it to bring the weight back down to something sane. I suppose it could also look nice on an OI or as part of a pit display.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 30-01-2012, 21:51
DonRotolo's Avatar
Back to humble
FRC #0832
Maybe a pit shower?
Unread 31-01-2012, 02:23
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Just a word of warning, when we were cutting our regolith to fit in a corner of our workspace, the powder and fumes that were created caused some of our students to become a tad bit nauseous. I do not think anything major happened, but if you have a sensitive stomach you may want to stay clear from the regolith when drilling/cutting/sanding it.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 31-01-2012, 02:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It's fibreglass. Don't breathe it in. Your stomach is the least of your concerns.
The silica from the fibres is probably a weak carcinogen and lung irritant (I say probably, because I don't know if the fibre shards are the right shape to embed themselves in lung tissue). The resin matrix isn't health food, but should be reasonably safe if you keep the temperature down so it doesn't decompose (i.e. don't cut it with a fast tool that will overheat it and generate fumes).
A NIOSH N95 mask is a minimum requirement; they're dirt-cheap. A respirator isn't a bad idea either.
Incidentally, the same goes for teams that use fibreglass structural extrusions—take appropriate dust-abatement measures.
