Go to Post do the math, then use the math to go for total overkill. - pfreivald [more]
Unread 27-01-2012, 16:09
AuraAmbience AuraAmbience is offline
FRC #3952
AuraAmbience is an unknown quantity at this point
Question Toggle Switches
Hi! We're thinking of using toggle switches to switch between autonomous programs, but we have no idea what kind of toggle switches to use. Can anyone give us some examples? Thanks!
Unread 27-01-2012, 16:15
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Toggle Switches
We've always used DIP switches, so you can have 2^n different autonomous variations.
Unread 27-01-2012, 16:20
FRC #3952
Re: Toggle Switches
Thanks! We'll be searching up on those.
Unread 27-01-2012, 16:21
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Toggle Switches
The best advice you can get: stop by your local Radio Shack and check out their drawers of component parts. Most of the switches, buttons, knobs, and such that are available there are suitable for use on the robot or on your OI. You get a wide selection, and can actually hold them in your hand and try them out before buying.
Unread 27-01-2012, 23:02
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: Toggle Switches
Depending on how many modes you have you can even just use a little jumper on the Digital Sidecar's digital I/O lines. You just need to connect the ground and signal lines together. More of a pain to set but less effort to build and it doesn't weigh anything.
Of course teams with lots of complex options would want something else I suspect.
Unread 29-01-2012, 23:49
gcschmit's Avatar
gcschmit gcschmit is offline
AKA: Geoff Schmit
FRC #3061 (Huskie Robotics)
gcschmit is an unknown quantity at this point
Re: Toggle Switches
I believe an alternative is to have a custom dashboard and set your autonomous mode via software instead of hardware.
Unread 30-01-2012, 11:28
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Re: Toggle Switches
In the past when we've tried doing setting autonomous from the drivers station inputs we found they weren't visible to the software until after the end of autonomous. Has anyone been able to make this work at a competition?
Unread 30-01-2012, 12:40
Re: Toggle Switches
They aren't available in autonomous mode, but they are available before autonomous mode.
Unread 30-01-2012, 12:55
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Re: Toggle Switches
So you can read the operator's console when the robot is disabled waiting for the match to start? I never would have guessed. Have you been able to do this at a competition?
Unread 30-01-2012, 13:00
Re: Toggle Switches
Yes, that works. You can also definitely read values from the Cypress board during Auto mode (though I have tested at home and they appear to be "locked in" by either the DS or networking code at the start of auto, they read whatever they were at the start of the Auto mode).
