Go to Post Courtesy is the key. - Tom Schindler [more]
Unread 23-03-2010, 18:30
kansattica kansattica is offline
FRC #2240
kansattica is an unknown quantity at this point
Spike motor control
We are trying to make a motor go on/off with a spike switch, we are using LabView. Please help thank you.
Unread 23-03-2010, 20:28
Re: Spike motor control
Before you get carried away, remember that Spikes can only control certain types of motors. You cannot use CIM or FP with a Spike.
Unread 24-03-2010, 09:45
Racer26 Racer26 is offline
You would need to give us more information than this. What joystick/button/other condition do you want to cause the motor to switch on and off, what ports are things connected to, etc.
Unread 24-03-2010, 23:00
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Thanks alot, because we hadn't known that you can't use a CIM motor with a spike. I guess we're gonna be using an old Victor, then. Thanks.
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 30-01-2012, 09:07
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Al: why can't we control an FP with a Spike? current?
Unread 30-01-2012, 11:37
fovea,
The robot rules restrict the CIMs and FP motors to speed controllers only. I however, recommend that teams be very careful when choosing what devices to use. The Spike is only designed to switch 20 amps, based on the specifications of the relay contacts used. However, several other motors have high stall currents as well. Some of the Banebots, AndyMark and possibly even an ARA motor since we have no specs on what motors teams may find all have higher stall currents than should be used with the Spike. While the Spike has worked for years in controlling the compressor, the old one only draws 25 amps for a short duration during start and then falls to 12 amps. The new compressor is just a little less. It is for this reason on the compressor Spike only, can the fuse be replaced with a 20 amp breaker.
Spike to CIM Motor Zultraranger Electrical 6 03-02-2010 17:20
Globe motor to spike controller stephenthe1 Motors 25 19-02-2006 23:03
Spike Control Line Signals Venkatesh Electrical 11 27-06-2005 07:23
Motor Question- Victor/Spike? 1166 Motors 10 16-02-2004 16:57
