Go to Post Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... - Rich Kressly [more]
Unread 26-01-2012, 21:55
Muffinz's Avatar
Muffinz Muffinz is offline
FRC #0088 (Tj (squared))
Team Role: Student
Muffinz is an unknown quantity at this point
Fixed Angle vs. Adjustable angle Shooter
So team 88 is faced with the decision to make our shooter mechanism at a fixed angle and adjust velocity of the balls.
OR
Make the shooter mechanism able to adjust up and down to change the angle. This would also require a change in the velocity at which the ball is fired.
Personally i believe it should be at a fixed angle and only adjust the velocity of the ball to preserve simplicity but some of my teammates disagree.
I was just wondering what the robot community thought on the matter.
Thanks,
Team 88
Unread 26-01-2012, 22:13
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Fixed Angle vs. Adjustable angle Shooter
401 is in the same predicament. We started testing tonight at different locations and distances to make more than an educated guess. Right now we are still nowhere close to a verdict, but hope to reach one by Saturday night.
I highly recommend that you get a quick test plan and test different angles. Even if it means jacking the front end of your robot up to achieve different angles of departure. We were surprised with some of the responses we got. We found that sometimes the 'sweetspot' was achieved more effectively at much lower speeds than we had anticipated.
Just some food for thought. Do the engineering behind it and test your assumptions. Some will be right and some will be wrong, but that is ok. Just remember to take multiple shots from the same data set (i.e. angle and speed setting)
Goodluck and I will see you guys at Chesapeake with The RoboBees
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 26-01-2012, 22:34
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
3677 feels it would be much easier to adjust the speed (accurately?) than to adjust the angle... for us anyway.
Unread 27-01-2012, 12:41
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
We're facing the same dilemma, and attempting to make the decision within the next couple of days. The main disadvantage we see to a fixed-tilt shooter is the need for a moderate take-off angle at the key and beyond (30-45 degrees) versus a steep angle if we wanted to make a high basket from up close, like touching the fender (75-85 degrees). Not that we're pursuing a strategy of scoring from all over the field; we're just trying not to limit our choices too early in the season.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 27-01-2012, 12:57
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Again, we too faced this same question.
Because simplicity is one of our key goals in designing our system, we really had to decide which would give us the greatest control.
We knew we already needed a way to have reliable RPM for the shooter, so we choose to go with that for our primary control over distance.
Once we prototyped a couple of different designs, we also decided to add a two position hood.
So, our final solution.......both.
Unread 27-01-2012, 13:50
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
My team sees a little bit of benefit to being able to adjust the angle of the shot, even if it is just 45* OR 75*, we want there to be some control over it. We prototyped some designs for throwers, and now that we've got one that we like, we're in the process of constructing a fixed 45* thrower, just to have a final, to-spec design that we can pass off to the programming sub-team. This way they can start getting the measurements they need to calibrate aiming code, and while they're doing that the mechanical sub-team will get to work on building a variable angle "hood" (for lack of better term). It should be interesting how each team solves the same problem!
-Mentor-
-UMass Lowell '13-
-Former Team Lead-
Unread 27-01-2012, 18:17
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
We decided on a fixed angle. Our prototype shot well up close and from the top of the key at 60 degrees. We're going to try 70 degrees today to compare.
Unread 28-01-2012, 18:07
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Probably adjust the shooter up and down to aim. It's more complex, but I say more accurate and easier to aim.
No leaks. Ever.
Unread 30-01-2012, 11:54
j.maguire25's Avatar
j.maguire25 j.maguire25 is offline
FRC #4107 (Team Storm)
j.maguire25 is an unknown quantity at this point
Our team decided on a fixed angle with adjustable speed. It would be simpler in the sense of using less motor's and etc. You would need more motors, gears, pistons, POWER, and whatever else you are using to cause the platform to raise, and to make the pitching devices speed adjustable. Also, making more things move and adjust leaves more room for mistakes.
