Go to Post Looks like I'm late, but in the grand tradition of Chief Delphi, I'll butt in and beat the dead horse anyway! - PayneTrain [more]
Unread 29-01-2012, 23:39
Sinani201 Sinani201 is offline
AKA: Daniel
FRC #1836 (Milken Knights)
Sinani201 is an unknown quantity at this point
GetParticleAnalysisReport causes crash
Whenever I try to use the command GetParticleAnalysisReport, the robot stops working and I have to reboot it. Not sure why this is happening. Here is the code:
ColorImage* camerain = camera->GetImage();
BinaryImage* binImage = camerain->ThresholdHSL(0,9,0,5,250,255);
int numParticles = binImage->GetNumberParticles();
delete camerain;
ParticleAnalysisReport* report;
for(int i = 1; i<=numParticles; i++)
	binImage->GetParticleAnalysisReport(i,report);
	// Other processing stuff
delete binImage;
This happens the very first time GetParticleAnalysisReport is called, so it doesn't have to so with overwriting the report variable (though I don't know if this will end up being a problem later).
Any help would be greatly appreciated.
Unread 29-01-2012, 23:57
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: GetParticleAnalysisReport causes crash
I'm not sure if this would actually cause a crash, but the function you're using ends up calling imaqMeasureParticle which likely takes a zero-indexed particle number. You're starting at 1.
Unread 30-01-2012, 03:54
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
If you take a look at the source code of GetParticleAnalysisReport:
 * Get a single particle analysis report.
 * Get one (of possibly many) particle analysis reports for an image.
 * This version could be more efficient when copying many reports.
 * @param particleNumber Which particle analysis report to return.
 * @param par the selected particle analysis report
void BinaryImage::GetParticleAnalysisReport(int particleNumber, ParticleAnalysisReport *par)
 int success;
 int numParticles = 0;
 success = imaqGetImageSize(m_imaqImage, &par->imageWidth, &par->imageHeight);
 wpi_setImaqErrorWithContext(success, "Error getting image size");
 if (StatusIsFatal())
  return;
 success = imaqCountParticles(m_imaqImage, 1, &numParticles);
 wpi_setImaqErrorWithContext(success, "Error counting particles");
  return;
 if (particleNumber >= numParticles)
  wpi_setWPIErrorWithContext(ParameterOutOfRange, "particleNumber");
  return;
 par->particleIndex = particleNumber;
 // Don't bother measuring the rest of the particle if one fails
 bool good = ParticleMeasurement(particleNumber, IMAQ_MT_CENTER_OF_MASS_X, &par->center_mass_x);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_CENTER_OF_MASS_Y, &par->center_mass_y);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_AREA, &par->particleArea);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_BOUNDING_RECT_TOP, &par->boundingRect.top);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_BOUNDING_RECT_LEFT, &par->boundingRect.left);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_BOUNDING_RECT_HEIGHT, &par->boundingRect.height);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_BOUNDING_RECT_WIDTH, &par->boundingRect.width);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_AREA_BY_IMAGE_AREA, &par->particleToImagePercent);
 good = good && ParticleMeasurement(particleNumber, IMAQ_MT_AREA_BY_PARTICLE_AND_HOLES_AREA, &par->particleQuality);
 if (good)
  /* normalized position (-1 to 1) */
  par->center_mass_x_normalized = NormalizeFromRange(par->center_mass_x, par->imageWidth);
  par->center_mass_y_normalized = NormalizeFromRange(par->center_mass_y, par->imageHeight);
You will see that the parameter par is a pointer to the particle analysis report. The code is expecting the pointer is pointing to something. But the code that called the function passed in an uninitialized ParticleAnalysisReport pointer. That will caused an exception for sure. Where did you copy this code from? It should have a line allocating/initializing the ParticleAnalysisReport before passing it to the function.
Unread 30-01-2012, 04:08
mikets's Avatar
Software Engineer
Originally Posted by Sinani201 View Post
delete camerain;
delete binImage;
It looks like the code should have been:
delete camerain;
for(int i = 0; i<numParticles; i++)
    ParticleAnalysisReport = binImage->GetParticleAnalysisReport(i);
delete binImage;
Unread 30-01-2012, 12:00
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
The prior post is fine as well, but if you're still wondering the subtlety of why yours didn't work originally, see the // **CHANGE** line here...
delete camerain;
ParticleAnalysisReport report; // **CHANGE** - instantiates the real object and not just a pointer to it...(and then below...)
    binImage->GetParticleAnalysisReport(i,&report);  // **CHANGE** and now pass the address of the real object to the function so it can make modifications to your real object 'report' from above.
delete binImage;
The only other concern is it should be "for (i=0 ; i<numParticles; i++)" or you'll crash at the tail end of the for-loop for going out of bounds. Arrays in C always start with the '0' element ... not '1'.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 30-01-2012, 18:16
AKA: Daniel
Thank you all very much. It's working now.
Unread 30-01-2012, 18:17
mikets's Avatar
Software Engineer
Would you share how you solved your problem so other people can learn from it?
