Re: Problems running servos
I'm not fluent in that language at all, but the first thing I would check is to see if you have a jumper on the pins next to the servo output. Without that jumper, the servo will not get power to move at all.
Codewise: Try hardcoding a value and verify that it is (or isn't) hardware. If the hardcoded value works and the code doesn't. Good luck! Last edited by omalleyj : 30-01-2012 at 15:22. Reason: I can't read :-( |
One possible problem is that your servo is unusual and doesn't operate on the conventional signal range. We've encountered this problem before with Parallax servos. As a reference (I'm not sure about the actual DS output), since Hitec servos are the brand that FIRST recommends,
Did you remember to connect the 6V jumper for Servo power on the Digital Sidecar?
Hi everyone,
Thank you so much for your inputs (no pun intended ![]() One thought I did have was to make sure the port we are using has a recorded 6 V difference on the DSC which it does. I also did hardcode a value in for the servo and no response. The DSC is also getting power since we have other hardware hooked into it and it is functioning properly with the correct C++ code. I never thought about the servo not operating in the conventional signal range so that is something to look at. I am new to FRC so I am still learning where things go etc., but I do know some programming so I feel reasonably confident that the code is correct, especially since the analogous code for the motors work fine. For feverittm: If the 6V jumper were not present, what would happen? In other words, would there still be a voltage difference across the leads? Thanks everyone for your quick replies. |
The jumper is what applies the 5 Volt power to the hot pin on the pwm / servo outputs. Without it, the servos get no power.
#7
In your code, change the digital module to 1, instead of 2.
#8
What Joe said. Module numbers =/= Slot numbers, it's a semantics change this year that chokes people up who haven't followed everything. Once that changes, it should work fine.
#9
Changing the module to 1 did work!! Thank you so much for the help!!
