Go to Post Just remember to never take the "Us vs Them" mentality and you should come out all right. - Ian Curtis [more]
Unread 30-01-2012, 01:01
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
Re: pic: Encoder Graph
No not yet that seems to be the popular suggestion to fix this problem.
how would I go about sampling?
I know I would need to pull the raw value.
Do I store an initial value and then just add to it then divide it by my time?
John Fogarty
Unread 30-01-2012, 08:33
  1. Get new_value (of counts)
  2. delta_counts = new_value - previous_value
  3. speed = delta_counts / cycle_time* (scaled to whatever units you want to use for speed*)
  4. previous_value = new_value
*See posts 23, 24, & 26 of this thread.
Unread 30-01-2012, 09:16
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
I ran a quick test as well (not graphing the data or anything, just dumping it to the standard output) and found a similar amount of variation. I was using whatever WPILibJ defaults to for encoder decoding (1X? 2X? 4X?).
For what I'm writing, however, manual differentiation (to those who don't know what this means, it's the method Ether wrote in the last post) is easier to implement and completely effective.
Unread 30-01-2012, 15:07
Awesome, thanks this should really help out thanks for anyone who has been testing this along with me.
John Fogarty
Unread 30-01-2012, 16:01
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Just so everyone knows, from the US Digital website, the length of the on pulse for each channel in phase degrees is 180 +/- 16, and the quadrature delay between channels can be 90 +/- 12 degrees for the E4P encoder. If you're in 4x mode and timing the gaps between transitions to get the rate, the data that you got is what I'd expect it to look like based on the specifications!
Unread 30-01-2012, 16:20
Is that what the FPGA does? Times the edge-to-edge transitions, and then GetRate() returns a calculation based on only the 2 most recent edges (not averaged over several samples?)
Unread 30-01-2012, 19:12
That is my understanding, although I haven't seen it documented. If it's 4x, it divides by the the time for the next edge on the opposite input. In 1x, it divides by the time for the same edge on the same input.
Unread 30-01-2012, 19:54
I guess that would explain why you get a cleaner signal reading raw counts and averaging over the sample time, like you said.
Unread 30-01-2012, 21:48
DonRotolo's Avatar
Back to humble
FRC #0832
1440 per revolution
Is it me, or does that seem like an awful lot of pulses per revolution for just controlling its speed. I'd imagine 1/1000 of that data would be more than enough. Or?
Unread 30-01-2012, 21:56
Agreed, for the speeds associated with a ball-shooting spinning wheel.
1440/4 = 360 so it seems like he's running a 360 encoder at 4x.
Even at 60rpm that's 29 pulses every 20ms.
Unread 31-01-2012, 22:04
This code gave me a VERY constant RATE on my graph.
    public void getSpeed(){
        samples[counter] = Shooter_En.getRaw();
        counter++;
        Shooter_En.reset();
        if(samples[9] > 0){
            counter = 0;
            for(int i = 0; i <= 9; i++){
                sum = sum + samples[i];
            AVG = sum / 10;
            Rate =  AVG / 0.48;
            sum = 0;
John Fogarty
Unread 31-01-2012, 22:44
        counter++;
        Shooter_En.reset();
        if(samples[9] > 0){
            counter = 0;
            AVG = sum / 10;
            Rate =  AVG / 0.48;
            sum = 0;
Rather than putting the exact same post in two different threads, it's probably better to post a link:
http://www.chiefdelphi.com/forums/sh...9&postcount=27
http://www.chiefdelphi.com/forums/sh...6&postcount=29
Unread 31-01-2012, 23:15
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
What difference does it make? Isn't is just a counter in the FPGA incrementing? For a circuit like that, this rate is nothing. Am I missing something?
Unread 31-01-2012, 23:22
Depends on where he's going to put the encoder and whether the signal is going to the cRIO or the Jag.
If it's on a wheel spinning at 5000rpm (like to shooter wheel), then that's 120,000 pulses/sec.
cRIO:
https://decibel.ni.com/content/message/12523
Unread 01-02-2012, 17:29
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
cRIO:
Personally, I would not throw away dynamic range for zero benefit but still - it surprises me that the FPGA does not count that fast. This is good data to have - thanks again Ether!
