Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 30-01-2012, 14:29
smigs smigs is offline
FRC #3373
smigs is an unknown quantity at this point
Problems running servos
Hi everyone,
I am a coach on Team 3373 out of Warrenton, VA. Recently, our programming team was writing some code for a generic servo (I didn't think it was necessary to label the part number) in order to make sure we know how to write the code.
Displaying only the relevant portions, we defined a joystick (in Module 1) and a servo instance. Then we initialized the servo instance. We physically connected it to Module 2, Port/Channel 9. Afterwards, we noted because the joystick GetRawAxis function assumes values from [-1,1] and the Servo Set function assumes values from [0,1] we did a little algebra on the Servo Set argument.
Lastly, I printed to the driver station the value of the Servo Set argument and I saw it change as I moved the Xbox joystick. HOWEVER, the servo itself does not move.
We do have other code written (not displayed) which moves a motor and gets camera feed etc. which all work fine. But for whatever reason we cannot get the Servo to work. There are a limited number of functions for the Servo class so between trying different things and looking on Google, we just need a fresh pair of eyes. Can anyone make any suggestions? The code compiles when we run it. We obtained the skeleton of it from the Simple Robot Template in Windriver.
Many thanks,
Brian
#####BEGIN CODE #####
#include “WPILib.h”
class RobotDemo : public SimpleRobot {
Joystick Xbox;
Servo Elevation;
public: RobotDemo()
Xbox(1),
Elevation(2,9)
/* GetWatchdog().SetEnabled(false); */
void Autonomous() {
/* commented out code */
void OperatorControl() {
while (IsOperatorControl())
Elevation.Set((Xbox.GetRawAxis(5)+1)/2);
START_ROBOT_CLASS(RobotDemo);
#####END CODE #####
Unread 30-01-2012, 14:35
Cecil's Avatar
Cecil Cecil is online now
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Problems running servos
I'm not fluent in that language at all, but the first thing I would check is to see if you have a jumper on the pins next to the servo output. Without that jumper, the servo will not get power to move at all.
I'm right 90% of the time, so why worry about the other 3%?
Unread 30-01-2012, 15:19
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
I would just add to that: make sure the DSC is getting power, showing the 6V indicator lit, not just the 5V.
Codewise:
Try hardcoding a value and verify that it is (or isn't) hardware. If the hardcoded value works and the code doesn't.
Good luck!
Unread 30-01-2012, 15:42
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
One possible problem is that your servo is unusual and doesn't operate on the conventional signal range. We've encountered this problem before with Parallax servos. As a reference (I'm not sure about the actual DS output), since Hitec servos are the brand that FIRST recommends,
Originally Posted by HITEC
All Hitec servos require 3-5V peak to peak square wave pulse. Pulse duration is from 0.9mS to 2.1mS with 1.5mS as center. The pulse refreshes at 50Hz (20mS).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 30-01-2012, 15:49
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Did you remember to connect the 6V jumper for Servo power on the Digital Sidecar?
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 30-01-2012, 21:20
FRC #3373
Hi everyone,
Thank you so much for your inputs (no pun intended
One thought I did have was to make sure the port we are using has a recorded 6 V difference on the DSC which it does. I also did hardcode a value in for the servo and no response. The DSC is also getting power since we have other hardware hooked into it and it is functioning properly with the correct C++ code.
I never thought about the servo not operating in the conventional signal range so that is something to look at. I am new to FRC so I am still learning where things go etc., but I do know some programming so I feel reasonably confident that the code is correct, especially since the analogous code for the motors work fine.
For feverittm: If the 6V jumper were not present, what would happen? In other words, would there still be a voltage difference across the leads?
Thanks everyone for your quick replies.
Unread 30-01-2012, 21:46
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The jumper is what applies the 5 Volt power to the hot pin on the pwm / servo outputs. Without it, the servos get no power.
Unread 30-01-2012, 22:27
In your code, change the digital module to 1, instead of 2.
Unread 30-01-2012, 22:58
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
What Joe said. Module numbers =/= Slot numbers, it's a semantics change this year that chokes people up who haven't followed everything. Once that changes, it should work fine.
Attending: MN Duluth Regional
Unread 31-01-2012, 23:18
FRC #3373
Changing the module to 1 did work!! Thank you so much for the help!!
