Go to Post We do a disservice as mentors if we simply complain. We must inspire our students by showing them how we rise to the challenge and solve the problems we face. - Jon236 [more]
Unread 30-01-2012, 15:05
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
cRIO v43 == fail
Hi everyone,
We've had some problems. We had some drive code on our old robot. After updating to the new firmware and recompiling/deploying the code, we have an issue. We are getting an error:
>>>> ERROR: Allocating module that is out of range or not found: Digital Module 6
...in InitPWM() in C:/WindRiver/workspace/WPILib/pwm.cpp at line 33
WPILib was compiled from SVN revision 2993
Looking at the source for WPILib, this call goes back to SensorBase::CheckDigitalModule(). So this call:
nLoadOut::getModulePresence(nLoadOut::kModuleType_ Digital, 6 - 1)
is returning false, but it should return true. I can confirm that we do have a digital sidecar in slot 6. The cRIO Imaging Tool also says that the module is OK. I can't find the source for getModulePresence either.
Should I report this as a bug to WPILib? Since the source for getModulePresence doesn't appear to be in WPILib, it seems like it would be out of their control (at least, I can't find the definition with a find | xargs grep getModulePresence). I could try commenting the check out and see if that works...
I have quadruple checked the module, and everything looks good. The imaging tool says the module is installed correctly. But the runtime check is failing. Why... all these silly updates- the last version that worked correctly for me was v28... anyway, if anyone has ideas, your help would be MUCH appreciated.
Unread 30-01-2012, 15:12
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: cRIO v43 == fail
Due to the attempted compatibility with the cRio-FRC II and the cRio-FRC (the one you're using) you'll need to pass in a module number to your objects. Since your sidecar is in slot 6 you'll have to pass in a 2 (the second group of slots).
For instance,
Servo *pan = new Servo(2, PAN_PWM_PORT);
Relevant links:
http://mmrambotics.ca/wpilib/class_s...a533a54f4b7909
http://www.usfirst.org/sites/default...20System_2.pdf (page 12)
Unread 30-01-2012, 15:13
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
Do you also have a module plugged into port 2? also the new image has changed the numbering for modules. So check if you have it coded correctly. If you have a digital in slot 6 in your program it should be module number 2 not 6. And the digital in slot 2 should be value of 1 in your code.
Unread 30-01-2012, 16:11
Once you recognize that the modules are not addressed by slot number in the 2012 image, it all makes a lot more sense. The first module of any type is number 1; the second one is number 2.
Unread 31-01-2012, 10:27
I missed that. So it's 1, 2 - not 0, 1? And these will corrospond to the first/second sidecars?
Thanks!
As a side note, I like it better when they're addressed by absolute slot number. Makes coordination between electrical and programming easier, and that way you can keep track of what's on what slot (it'll look like the analog and digitals are on the same slot now). But if that's how it's done now...
Unread 31-01-2012, 14:51
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Yes, it's a step backwards.
I don't know what FIRST is thinking, but I suspect they are 'making it easier' when they are really making it harder.
I also suspect that FIRST wants to hardcode the slot locations so they don't have to probe the cRIO bus to find the analog and digital modules. The embedded FIRST code wants to address the analog module to get the battery voltage, and the digital module to flash the status indicator.
Unread 31-01-2012, 22:10
It's a way to make team code consistent between the 8-slot and 4-slot cRIOs.
