Go to Post As far as we know, FIRST could replace football by 2018! - Adam Richards [more]
Unread 21-01-2012, 17:59
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Calculating distance with an Axis Camera 206
Originally Posted by Solauj View Post
What problems are you having with OpenCV?
I am not using OpenCV at all, as I am running all of my code on the cRio.
If you are running the vision on the cRio, using NI Vision (CVI) is a much easier way to go, as it is already compiled for VxWorks, all of the supporting code (get image from axis cam) is already written, there is an example to process rectangles, and you can use NI Vision Assistant to automate a bunch of it.
Kettering Motorsports
Unread 30-01-2012, 16:15
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Originally Posted by shuhao View Post
There are numerous algorithms... we are trying opencv with relatively little success.
Anyone else have better experiences with opencv?
I am using the older version because I had big problems with new 2.3.1. I have starting to write the tracking algorithm I have detected the "parallelograms". Now here comes the math.
Unread 30-01-2012, 17:14
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Originally Posted by JewishDan18 View Post
Basically, yes. Involves a fair amount of trig, but this is how I am doing it, and it works well.
Correct me if im wrong, but cant you use a exponential regression for the correlation from height of rectangle to distance away (at least it seems a exponential regression is the right way to go)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 31-01-2012, 16:43
ganchara ganchara is offline
FRC #2523 (Hilltoppers)
ganchara is an unknown quantity at this point
Does OpenCV have a program that will spit out code for you similar to what the NI Vision Assistant program does? It seems like using OpenCV will be easier for my team to implement our rectangle tracking with if it does, as we are having some trouble understanding the code that is spit out by Vision Assistant.
Unread 31-01-2012, 20:59
caseydech caseydech is offline
None #1391
caseydech is an unknown quantity at this point
my team uses the axis camera to identify blobs (yes its the technical term for the... blobs that the camera picks up) And then finds the distance based on the pixel distance between top square and bottom square, angle uses trig and distance from side targets, labview can calculate the rest
Unread 31-01-2012, 21:21
Happy Birthday! Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
I have seen a lot of people over look this in past year. Make sure you are converting it to foot and inches or whatever you desire as 1' would be 1.2 as a double.
Unread 01-02-2012, 01:35
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Sure you can, but you need to get a baseline to start from, which can be found by going through the trig for one image, or going to a field and finding it through measurements there.
Yeah, this is what I hope to do, since the error is much less than using a single target. But, if one target is not found, you will need to do the math without it, which makes things very interesting (and a whole lot of if-else, unless I find a more elegant way to do it)
