Go to Post If all you've seen of an event is the three days of the competition, you've missed 99% of the work that made it happen. - Madison [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 30-01-2012, 16:31
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: LED Ring Light
Originally Posted by Mr V View Post
In the world of vehicle electronics crimp butt connectors are not considered robust. By reputable automotive electricians they are often referred to as emergency or temporary connectors or guaranteed failure points. For those that masquerade as "professional" technicians that use them they are referred to as job security.
Properly sized and installed crimp butt connectors are considered robust enough by NASA for use on spacecraft (per NASA-STD-8379.4). In fact, they are even acceptable with multiple wires entering one end of the splice. As always, the important thing to remember is "properly sized and installed".
My number one preference is always a properly done soldered splice connection, with heat shrink. Again, the important thing is "properly done", which means some sort of mechanical joint between the two wires prior to soldering, such as a hook splice or Western Union splice. Proper wire tinning. Solder not wicked up under the insulation.
What I was trying to get across in my original posting was that approaches like just electrical taping the two wires together are not "mechanically robust".
One of the biggest things to watch out for in any wire splice is to not damage the conductors when stripping the wires. It doesn't matter how good the splice is if the wire breaks off in your first match. And when it breaks inside the heat shrink tubing you applied over the splice (or inside the big sticky gooey wad of electrical tape you had someone gob over the connection when you were done), the wire won't necessarily fall off and be obvious why your light (or whatever) is not working. Or works intermittently.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 30-01-2012, 22:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: LED Ring Light
Cheap butt splices crimped with a simple pliers-like crimper is about as worthless as Mr. V asserts.
High-grade butt splices exist, and when used with the proper crimper, can exceed the reliability of the original wire, without solder.
It all depends on what you mean by butt splice, eh?
Unread 31-01-2012, 00:32
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: LED Ring Light
Yes but NASA doesn't use the insulated crimp connectors you'll find at your local hardware or auto parts stores and many FIRST Teams do. I should have been more clear that I was referring to those type of crimp butt connectors. Although they exist most people will be unable to locally obtain versions that are properly sized for splicing anything other than 2 wires of the same gauge. Either way the vinyl insulated connectors are next to impossible to determine if they have been properly installed (the "pull" test is not valid and may compromise a connection that was good) and most tools available at the same place that you buy those connectors are not capable of installing them properly. The insulated vinyl connectors are also known for cutting strands of the wire leading to the eventual failure of the wire.
Unread 16-02-2013, 10:45
Sargon2335 Sargon2335 is offline
FRC #2335
Sargon2335 is an unknown quantity at this point
Re: LED Ring Light
My team is trying to hook up the ring light. I already have a terminal strip in place, but we do not know which side is positive and which is negative. I have looked on andymark, the vendor's website, and many different threads on chief delphi. Do you guys know which wire is which? I was assuming the one that is tinted copper is positive, but I don't want to plug it in until I know for sure.
Unread 17-02-2013, 00:51
Re: LED Ring Light
Don't worry. It's okay if you connect the LED ring light backwards temporarily while you determine which wire is which. You won't break anything if you put battery voltage across it in the wrong direction.
(It'll break if you put too much voltage across it in reverse, but that would be just as bad for it in the forward direction too.)
